Re: Illuminated needles - How to fit. 11 years 11 months ago #51086
Did you get them from xtuners?
Re: Illuminated needles - How to fit. 11 years 11 months ago #51089
yes I should have got the needles at the same time doh!! I just wasnt sure what was coming :nonod:
Re: Illuminated needles - How to fit. 11 years 11 months ago #51095
He's a nice guy, sent me a replacement needle after Arthur stole one while I was putting them in. Chewed it to bits! :spank:
Re: Illuminated needles - How to fit. 11 years 11 months ago #51114
  • tui's Avatar
  • tui
  • Penelope Pitstop
This is something I want to do, so thanks very much for the great How To! :broon:
-=Visit my Website!=-
Illuminated needles - How to fit. 10 years 1 month ago #141154
I spent yesterday afternoon adjusting the new illuminated needles on my F.
I really wish I had re-read this thread before I did the needle swap-I wouldn't have done it! :oops:
I made the swap a couple of weeks ago, and when I had finished the only instrument reading correctly was the fuel guage (At least I think it is, I will have to see if the "E" is where it should be!)
Of the 4 instruments three of the new needles' holes were too big for the spindles, one (speedo) was too tight. The speedo one was easy to sort as I have a set of number drills so just drilled it so it was an interference fit. Glue was the answer for the others,
A word of advice...Don't use silicone as it doesn't grip well enough on the spindle. I used a thick super glue, but looking back plastic model glue may have worked better in the event the needles have to be removed again.
As for the adjustments, The first I attempted was the temp guage. As David recommended I got the car up to temp and glued the needle in the correct position. Of course, once the glue set it was reading too low. Apparently the weight of the needle makes a big difference to how it reads. :slapme: I tried adding a bit of weight on the little arm opposite the needle which at least got it onto the dial. As I glued the rotten thing on with super glue it will be staying where it is for now as I don't feel like pulling the cluster apart again. For the time being operating temp will be at 20% on the dial rather than 40%. :rant:
The next was the speedo. Like David I hooked up the satnav (Called a GPS over here), got up to a certain speed (40KPH worked for me) and pushed the needle in place. Of course, due to the weight of the needle it was way out! :slapme: I found that if I put it on reading high I could pull over and move the needle on the spindle once it hit the stop. (Let's hear it for the interference fit!) It did take several tries to get it right but it's currently reading within 1kph so that's close enough. One thing that the different needle weight caused was a loss of readings under 15kph as the stop point is different. :bang:
The last instrument tackled was the tach. I thought this one would be easy, but of course I was wrong! I tried hooking up my old timing light which has a digital tach, and which I haven't needed since I bought the MGF. I couldn't get the tach on the unit to read. Must be something to do with the MGF ignition. Very frustrating! :bang:
In the end I hooked up the Toughbook with the Blackbox diagnostic sofrware. Blackbox has a tacho test function where it pings the tach up to 3000 rpm repeatedly. I used this to set the tach reading at 3000rpm, again having to take into account the weight difference in the needle. I put some time into trying to balance the needle by adding weight to the reverse of the needle and this seemed to help.
I'm still not sure if the tach is reading correctly. I'm hoping that the Blackbox setting of 3000rpm is accurate.
Would someone be able to tell me what their tach reads at a steady 30MPH (or 50KPH) in either 2nd or 3rd gear?
That would be appreciated!
Next weekend I will be swapping out my dash and console. I'm hoping that will be more straightforward as it is simple swapping of parts. I do plan to have a bottle of Tequila on hand in case the job goes south. :bust:
Re:Re: Illuminated needles - How to fit. 10 years 1 month ago #141171
Once you recover from the trauma of the fitting process (6 months of therapy worked for me) you do come to appreciate the pleasing effect of this modification.:rofl:
Sent from my K701C using Tapatalk
Illuminated needles - How to fit. 10 years 1 month ago #141175
Am I the only one that doesn't mind the standard instrument set up?
In fact, I quite like it, I find the magnolia colour, very easy on the eyes, offering a minimum of glare, unlike some car that seem to have retina burning displays.
I would've thought with my crook night eyesight that I would have more reason to worry about it than most.
Illuminated needles - How to fit. 10 years 1 month ago #141181
I do like the standard stuff but I prefer illuminated needles. We've got them on the PT Cruiser and they are nice to drive with at night. I'm half tempted to pick up a set of PT Cruiser instruments just for the needles. They have a larger cap on the center which would do a better job of controlling the illumination from the LEDs. Mind you, I'm not about to take the whole lot apart again! :pinch:
Illuminated needles - How to fit. 9 years 3 weeks ago #158189
Well......I've now had the illuminated needles in place for over a year....and I am now searching for a set of replacement guages (Not so easy as mine are in km!)
I have found that the temp and fuel guages work fine. Not sure how accurate they are but they are consistent and I have got used to them. In my installation notes post above I mentioned that the needles seemed out of balance and how I tried to balance them. This ended up not working. I find that the speedo is dead on up to 100KMH then rapidly loses accuracy as the needle goes "over the top". When the speed on the satnav reads 120 KMH the speedo reads 160! Good for the ego, but not good for seeing how fast I am actually travelling. I worry that the tach has a similat balance problem although it's travel does seem more accurate.
I'm now looking on Ebay.de for a set of guages with a km speedometer.
Oh yeah...I have also found the colour on the needles is fading from red to sort of an amber. :pinch:
Illuminated needles - How to fit. 11 months 2 days ago #202699
Hi people, apologies for waking you all up lol, but I have just found this thread, I was looking to do this to my mk1 F which you know is analogue.
does the back lit only light up the segments between the numbers and do you keep the light box to illuminate the clock faces ?
do I need to change the faces, i dont fancy the plasma look tbh but would like the segments, numbers and text to be back lit too.
Also do you still have to re calibrate everything after.
Tia
Time to create page: 0.133 seconds
