MY MGTF QUAD LED LIGHTS
  • rayb
MY MGTF QUAD LED LIGHTS was created by rayb
Posted 13 years 1 month ago #28714
just finished fitting the quad lights ive had knocking around the shed, fitted hella leds to the brake and side lights but will change again as im looking at fitting led flashing indicaters aswell.
side lights on
side lights and hazrds on
side and brake lights on
on the left is 1 reverse light and the right is 1 fog which i will change for a 2nd reverse and move the fog to just under the number plate
Last Edit:13 years 1 month ago by rayb
Last edit: 13 years 1 month ago by rayb. Reason: up load of pics
Replied by David Aiketgate on topic Re: MY MGTF QUAD LED LIGHTS
Posted 13 years 1 month ago #28722
Looking good! I think they suit the car well! :thumbsup:
  • rayb
Replied by rayb on topic Re: MY MGTF QUAD LED LIGHTS
Posted 13 years 1 month ago #28724
well dave i did fit them to the mgf but they didnt seem to suit it so i took them off and kept them as i was going to buy a mgtf , i to think they suit the mgtf very well.. :thumbsup:
by rayb
Posted 13 years 1 month ago #28727
They seem to fit in with XPG very well! :broon:
  • rayb
Posted 13 years 1 month ago #28729
anybody who would like these and dont know how to fit them give me a shout as they are really easy to fit. :thumbsup:
by rayb
  • rayb
Posted 13 years 1 month ago #28732
pics if anybody is interested in what they looked like on a mgf leds then a changed to the fiat coupe lights
by rayb
Replied by Laz1957 on topic Re: MY MGTF QUAD LED LIGHTS
Posted 13 years 1 month ago #28743
I think a 'how to' is called for here :yesnod:
by Laz1957
Replied by Rich in Vancouver on topic Re: MY MGTF QUAD LED LIGHTS
Posted 13 years 1 month ago #28747
Very Nice!
I agree that they look better on the TF.
I do think the LEDs look much better. :thumbsup:
Replied by leotinius on topic Re: MY MGTF QUAD LED LIGHTS
Posted 12 years 6 months ago #49876
- where do i install the wires? (i dont want to connect it directly to the battery because its dirty)
- what is the deal with grounding wires (how many will i need and where?)
- i have a 125VAC illuminated rocker switch and have no idea why there are 3 prongs (is the middle one for grounding or something? if it is for grounding, will i be able to place only 1 ground wire for my entire setup?)
- i got a fuse holder and need to know where to place it. (could i use one of my cars own fuse slots instead?)
- would i be able to connect 2+ LED strips to one switch?
- any other general information would be greatyly appreciated
as you can see, i'm trying to get this done with limited knowledge but i am going to give a fair attempt.
thanks to everyone who offers their help.
LED Tube
LED Panel Light
LED Spotlight
Posted 12 years 6 months ago #49897
Firstly,:welcome2:
What is it that you are wanting to do with these lights?
You can take a live from the battery or from an appropriate place in the fuse box, depending on what the total current you will need to power all your light components.
The fuse holder should go into the primary live feed for your new lighting circuit.
The three connectors are for live+; feed to lights; and switched live from the car light circuits to illuminate the switch. If all the lights are leds you will be able to connect all through the 125vac switch. Up to about 9 amps total.
You would need a ground from each light. These could be all connected to one earth point or kept separate, whichever is most convenient.
Last Edit:12 years 6 months ago by David Aiketgate
Last edit: 12 years 6 months ago by David Aiketgate.
  • Visitor
  • Visitor
Replied by a Guest on topic Re: MY MGTF QUAD LED LIGHTS
Posted 12 years 6 months ago #49906
leotinius :welcome:
as for your question I have not got a clue but someone will have B)
  • rayb
Posted 12 years 6 months ago #49942
not sure what you mean , but if you are fitting the satur quad lights surround with the leds i put all the earths together on one side (connected) then used a volt tester to indentify what lights were which and connected them up, do the same for the other side . i then fitted my rear fog light in the rear bumper this gave me a spare wire from the rear fog lights , i taped this up. also if fitting flashing indicater leds you will also need 2 resisters so the flash at the propper rate.. hope this helps
by rayb
Time to create page: 0.565 seconds
