T-Bar Event badge.
- Leigh Ping
I was thinking that perhaps we should wear some form of identifying badge, sticker, hat, flower or whatever. I'm sure that this idea has probably occurred before now. Here's my solution to the problem that we can all share in if we want too.
First off, It will cost you £1.75 to do this. So be warned.
***It's a 25mm, or one inch, ebay badge with your name or forum name on it. Clickety click here & PLEASE ORDER A YELLOW ONE WITH 'ROCKO' TEXT IN BLACK. So we can spot each other more easily***
Order a yellow one with black 'Rocko' text, if you could please. it will help us to stand out more to each other. Mine will say:-
T-Bar
Or, depending how it fits on the badge (I'll give the printers the final say).
Ping
T-Bar
It's only 25mm or one inch in size. That should be enough to ID us to each other. If you have a better suggestion, badge design or text idea then please share it.
Update - 31/01/12 The badge arrived.
NOW DON'T FORGET TO KEEP IT IN YOUR CAR.
- a Guest
- Visitor
- pendle lass
At least I did have a sign it was last seen on a portaloo door on the Devon run :nonod:
- a Guest
- Visitor
I have ordered mine Leigh same as yours
- Leigh Ping
What does your badge have on it please?Softly~Softly wrote: I have ordered mine Leigh same as yours
- a Guest
- Visitor
T-Bar.com
:yesnod:
Even on Sunday's run it was a bit confusing with so many new faces/new names to remember.
- Tourbillon
- a Guest
- Visitor
Many thanks for your purchase and payment. I just wanted to check something though. I tried typing in T-bar.com and there didn't seem to be a website there but there was one at The-T-Bar.com. I just wanted to check that you hadn't made a mistake when sending through the note?
As you will see below, I've attached the two options, both using the ROCKO font on the yellow badge, but one with the 'The' and one without.
If you can confirm which one you'd like to go ahead with that'd be great.
Thanks
Kristian
I am telling him to add The
I still have mine from the FRL run so I will use that, however if you do not spot the badge then I look like this.....................
- Leigh Ping
Softly~Softly wrote: Hi Jan,
Well spotted that man.
We all know what it means if it just says 'T-bar'. So, I'll go with that.
T-Bar
- a Guest
- Visitor
Red Devil wrote: Great idea Leigh :broon:
In your dreams
