TF Air intake on an F - How to upgrade.
- bryan young
Replied by bryan young on topic TF Air intake on an F - How to upgrade.
Posted 11 years 8 months ago #107842Jimuth wrote: If no TF air intakes are available, is there anything that can be done with the original intake?
I bought a new one from B&G on ebay thirty odd quid delivered. I cut out the ond box with a rip saw, two cuts in front and top, didnt move the servo and used RPs advice from below. I used stainless bolts, nuts and washers.
by bryan young
Replied by KFMGTF on topic TF Air intake on an F - How to upgrade.
Posted 8 years 6 months ago #167552
These How To's are cracking!! I'm about to do this job on my TF to cure a leak - may I ask, did you fit a new foam seal as well as the silicon?
by KFMGTF
KFMGTF wrote: These How To's are cracking!! I'm about to do this job on my TF to cure a leak - may I ask, did you fit a new foam seal as well as the silicon?
I just siliconed mine, both on my old F and my TF.
The foam gasket was still on the snorkel I bought, I just cleaned it and siliconed over it.
Last Edit:8 years 6 months ago
by Bob
Last edit: 8 years 6 months ago by Bob.
The following user(s) said Thank You: Leigh Ping, KFMGTF
Replied by talkingcars on topic TF Air intake on an F - How to upgrade.
Posted 8 years 6 months ago #167557
Personally I wouldn't use the gasket if using silicon sealant.
by talkingcars
The following user(s) said Thank You: KFMGTF
Posted 8 years 6 months ago #167573
Cheers, im going to see if I can grab a new foam seal and use silicon as the plastic is slightly warped. Whilst taking it all off I noticed the bolts holding the unit in place were either loose or missing!!!
Also ended up giving the whole under bonnet area a thorough clean up
by KFMGTF
Replied by Devinci on topic TF Air intake on an F - How to upgrade.
Posted 4 years 3 weeks ago #194499
Going to do this next week together with a home made brace to stiffen up the brakeservo.
Here come`s my stupid quistion of the the day @adamelphick , does the wooden spacer stay in or is it just temoprary ?
by Devinci
Time to create page: 0.536 seconds
