Gear cables - How to Change.
- Rich in Vancouver
Replied by Rich in Vancouver on topic Re: There's always something! Gear cable this time.
Posted 13 years 3 months ago #26893Please Log in or Create an account to join the conversation.
Replied by Laz1957 on topic Re: There's always something! Gear cable this time.
Posted 13 years 3 months ago #26896Please Log in or Create an account to join the conversation.
- Rich in Vancouver
Posted 13 years 3 months ago #26898Laz1957 wrote: I could have done with that advice a few years ago (ooh err matron!) :lol:
According to your profile I am 3 months older than you.
With age comes wisdom.
Posted 13 years 3 months ago #26917However, the backplate is a mess
It needs a slight adjustment, as the gear knob is a bit too forward. Is it possible to adjust this from the gearbox end as well as the gear lever end?
This was the first time it's been driven with the new TT Mk4 exhaust, which was fun :woohoo:
Not sure what to do about the backplate though
- bryan young
Replied by bryan young on topic Re: There's always something! Gear cable this time.
Posted 13 years 3 months ago #26920Please Log in or Create an account to join the conversation.
- Rich in Vancouver
Posted 13 years 3 months ago #26925After getting everything back together yesterday I went for a really nice test drive along the river. All forward gearsworked great but reverse was hard to engage with grinding.
I figured that one turn of adjustment would sort it out as it was very close. Today, anticipating a quick half hour fix I had at it and ended up trying every possible combination of adjustments. That's when I found out about the internal travel limit and also when I found out that my gearlever assembly is knackered. The combination of wear in the nylon bushing that converts the vertical movement of the cross gear assembly to back and forth movement for the cable, and wear in the shift lever bushing where it sleeves over the cross gear rod causes the counterweight to foul on the cables. There really is very little clearance under there so the accumulation of small amounts of wear creates a problem. To top it off the excess play also meant the gearlever fouled on my nice new MK II gearlever surround :rant:
The net result is I'll be driving the old rattletrap TR until I come up with enough cash for a slickshift. (Which should solve the problem he says optimistically)
Cheers,
Rich
Posted 13 years 3 months ago #26941Were you driving without the backplate and, if so, did you do anything to fill the gap at the back of the transmission tunnel?
- Rich in Vancouver
Posted 13 years 3 months ago #27026As mentioned earlier I am considering just stuffing a plastic bag with bits of fireproof insulation (I will have to talk nicely to the plumbers at work) and pushing it into the tunnel from the cubby. If it ever reaches the stage where flames are coming through that hole I will either be sprinting away from the car or will already be a goner. :silly: (Knock on Wood!)
Has anyone talked nicely to Clive to see if he can get more of his stainless plates made?
Replied by David Aiketgate on topic Re: There's always something! Gear cable this time.
Posted 13 years 3 months ago #27031David
- Rich in Vancouver
Posted 13 years 3 months ago #27035Give a man a whistle and see what happens!
Posted 13 years 3 months ago #27036David
Replied by David Aiketgate on topic Re: Gear cables - How to Change.
Posted 13 years 3 months ago #27079David
