Little advice - (alternator + battery)
  • Blueser
  • Journeyman MGer
  • Journeyman MGer
  • ROVER 25 iS 1.4 76 KW
Little advice - (alternator + battery) was created by Blueser
Posted 12 years 9 months ago #38981
Control alternator + battery - For those who do not know. ;)
When the engine is started and included the majority of consumers filling should be about 14 ± 0.5 volt, depending on the Ah battery and the number of consumers involved, the alternator charging well.
When the engine is turned off on the battery voltage should be 12.6 V at the correct battery.
Vladimir
Last Edit:12 years 9 months ago by Blueser
Last edit: 12 years 9 months ago by Blueser.
Replied by MGF MARK on topic Re: Little advice - (alternator + battery)
Posted 12 years 9 months ago #38985
the above is partly correct as the voltage charging the battery can be as high as 14.8v dependant on load ect as per ISO 13766
also a fully charged battery can give 13.00v with no load
also depends on the quality of the multimeter
best to use a good quality one above the £80 cost
mad about cars and bikes :)
Last Edit:12 years 9 months ago by MGF MARK
Last edit: 12 years 9 months ago by MGF MARK.
Time to create page: 0.502 seconds
