10 Min Rover 800 Wiper-light Stalk Upgrade
Not a problem but a 10 minute aesthetic upgrade. The Rover 800 / Freelander stalks feel so much better and look OEM compared to the thin shiny black stalks fitted as standard, which look slightly out of place. The stalks are a direct replacement and use the same connectors as the F/TF.
Note: There is no need to remove the steering wheel to change the stalks
Tools needed;
Small cross head screwdriver and a thin flat blade (I used a paring knife).
Preparation;
I went on ebay and for the princely sum of £1.99 won a set of Rover 800 stalks. My postman was slightly intrigued by what I was up to now when handing over the parcel
Remove the two stalks by removing the two retaining screws on each side and then use a blade to release them from the main housing.
Now you know how they come out, take the two stalks to your car...
The loose connector on the wire does not connect to anything on the F/TF, this is for the variable time intermittent wipe on the 800.
The Fix;
1) Remove the screws holding the steering column trim and remove trim
2) From the straight ahead position rotate the steering wheel 90o clockwise to expose the retaining screws on the wiper stalk.
Remove the two screws and connector then replace the wiper stalk then refit the two screws.
3) Rotate the steering wheel to expose the retaining screws on the lights stalk.
Remove the two screws and connector then replace the light stalk then refit the two screws.
4) Refit the steering column trim – there you go 10 minutes job done
Now enjoy your shorter, chunkier stalks which not only feel much better quality but actually look like they were designed for the car, looking more OEM than the thin shiny black ones.
The new wiper stalk does have a variable speed intermittent slider setting which is not compatible with the F / TF. I know a lot of people have had a look into this but I’m not sure if an easy usable solution has been found. Personally I don’t use the variable timer wipe on the other cars I have anyway. If you know of an easy fix for the variable time wipe then feel free to add it below.
- adamelphick
Replied by adamelphick on topic Re: 10 Min Rover 800 Wiper-light Stalk Upgrade
Posted 12 years 6 months ago #48160Please Log in or Create an account to join the conversation.
Replied by PQD44 on topic Re: 10 Min Rover 800 Wiper-light Stalk Upgrade
Posted 12 years 6 months ago #48162Like I said for me I don't use it on my other cars so I don't mind.
- adamelphick
Posted 12 years 6 months ago #48163Please Log in or Create an account to join the conversation.
Replied by David Aiketgate on topic Re: 10 Min Rover 800 Wiper-light Stalk Upgrade
Posted 12 years 6 months ago #48164Nice modification, though :broon:
Replied by bensewell on topic Re: 10 Min Rover 800 Wiper-light Stalk Upgrade
Posted 12 years 6 months ago #48167Please Log in or Create an account to join the conversation.
- Leigh Ping
Replied by Leigh Ping on topic Re: 10 Min Rover 800 Wiper-light Stalk Upgrade
Posted 12 years 6 months ago #48170Please Log in or Create an account to join the conversation.
Posted 12 years 6 months ago #48183Please Log in or Create an account to join the conversation.
Posted 12 years 6 months ago #48185There are more so do a search if your interested. All the Rover 800 ones were more expensive
Replied by andy1970h on topic Re: 10 Min Rover 800 Wiper-light Stalk Upgrade
Posted 12 years 6 months ago #48188Still didn't fix the horn and nor did a wheel swap
Back with front wheel drive and 181HP at the wheels
Posted 12 years 6 months ago #48190Please Log in or Create an account to join the conversation.
Replied by talkingcars on topic Re: 10 Min Rover 800 Wiper-light Stalk Upgrade
Posted 12 years 6 months ago #48191In my experience of 80's and 90's Rovers there will be a small ECU somewhere controlling the veriable speed wipers.
If I can find a copy of Rave or similar info for the 800 I'll try and work it out.
(anyone got a copy/)
