How to Take a Door Off
So I took a door off while I've been tinkering. Here's how i did it...
WARNING Very Pic Heavy.
Step 1; remove the door trim using this guide by CCJ:
Door card. - How to remove.
Then take the internal hinge off by hitting it with a punch or waggling some pliers on it. You're aiming to pull it up and out.
Next time to take the speaker out. There's three cross head screws.
Then unclip the wire holder from its holder with a screw driver or pliers.. WARNING don't get giddy or you could break something.
Next theres a lot of wires in the bottom of the doors for the window mech. Be careful and unclip them.
Last Edit:12 years 4 months ago
by bensewell
Last edit: 12 years 4 months ago by Leigh Ping. Reason: Tidied up. Great guide. Thanks Ben :)
The following user(s) said Thank You: philljoynes, Jimuth
Next unclip the "Door Snake" that holds your wires in with a screwdriver.
And pull the wires from your door card up and out of the hole where the door snake lives.
So now the wires are out shut the door slightly and start taking the nuts off. You'll need a ratchet spanner or ratchet handle and socket like what I used.
But some of the bolts / nuts whatever you want to call em are a bit tight for the standard ratchet so I had to get the "mini me" 1/4" ratchet out to take the ones you can't reach.
Here he is bless him :broon:
by bensewell
The following user(s) said Thank You: tui
Now its magic time. You need to hold the door with your leg as the hinges are off or it will fall off and hurt you and your pride.
So press on the door with your knee then pick the door up from the other side. Theres loads of gaps in the metal to choose from.
So its off but it somewhere safe and scratchfree.
by bensewell
The following user(s) said Thank You: tui, Yellow Peril
- Rich in Vancouver
Replied by Rich in Vancouver on topic Re: How to Take a Door Off
Posted 12 years 4 months ago #57029
Very well done Ben! :broon:
I particulary liked the clever graphics.
One question.....Why did you take your door off? :dry:
I'm stripping the mk2 F i have in my garage. Bought it for £300 had about £600 worth of parts and counting off it
by bensewell
- Leigh Ping
Another great guide Ben. Cheers. :broon:
by Leigh Ping
- a Guest
- Visitor
another very quick way is to open your door just as a van is passing as one of my customers did,very fast and a very clean way of door removal.and you dont have the hassle of storage and lifting the dam thing.
- a Guest
- Visitor
lol Daryl ...
Ben seriously well done babe, that is a great how too :broon:
Great How To Ben! :broon: Amusing read too!
by tui
Is it possible to remove a door without removing the wing as well ?
by amtcoupe
I'll tell you tomorrow.
I am trying to take the hinges off (bottom one) and the only way I can see is to go in through the wheel arch, so tomorrow the wheel comes off and the wheel liner comes out.
I'll look forward to it .
Looking at it today I wondered if the door would go back far enough with the "stop strap" removed to allow access to the bolts on the door side of the hinges rather than the A pillar ones ?
by amtcoupe
Time to create page: 0.568 seconds
