MGF Rear Track Control Arm - How To
Replied by Diesel Destroyer on topic MGF Rear Track Control Arm - How To
Posted 12 years 1 month ago #74353
PQD44 wrote: Not sure on that one Clive. When researching I only ever saw them listed for the MGF :dry:
I have a TF rear set up Clive...
Will have a look at the poly bushes when they arrive and see if they fit the TF if that helps?
Replied by PQD44 on topic MGF Rear Track Control Arm - How To
Posted 12 years 1 month ago #74393
Ouch :pinch: that's expensive I only paid £6.50 from my local motor factor.
Replied by peter81 on topic MGF Rear Track Control Arm - How To
Posted 12 years 1 month ago #74409
cjj wrote: I wonder if the poly bush kit would fit the TF arm.
if I have not misunderstood what you are saying, this if for TF
front http://www.polybush.co.uk/shop/458_Kit_107_MGTF_Front_Suspension_Bush_Kit
rear http://www.polybush.co.uk/shop/461_Kit_108_MGTF_Rear_Suspension_Bush_Kit
by peter81
Posted 12 years 1 month ago #74413
How to strip the other end..
There is a big side and a little side..
On the big side is a ring which has to be removed (smashed up)
Smash it up totally
Then pull the ring off and tap the rest out from the small side
Then clean up using wire brush in bench grinder
Ready for paint
The following user(s) said Thank You: David Aiketgate, PQD44, Leigh Ping
Posted 12 years 1 month ago #74467
Allan that is a big help thanks for adding that :yesnod:
Yes Peter the link you provided should include the bush required for the TF. Labelled 38G above
Looking on the Rimmer Bros site they show item one (adjustable lower arm) as no longer available and recommend you to purchase a non adjustable part, part two?
Link to Rimmer Bros site - MG TF Rear Lower Arm
Replied by Diesel Destroyer on topic Re: MGF Rear Track Control Arm - How To
Posted 12 years 1 month ago #76841
Just a quick heads up..
I ordered the poly bush set from the place that sells the set as a pair.. The second link nearer the end of the page 1...
And nothing yet...
Will e mail them today
Posted 12 years 1 month ago #76968
Just had an E mail from Dan at DC Performance
They processed the order on the 1st... But they buy they bushes from Polybush and its there that is the problem..
He is chasing them again today
Will keep you posted
Last Edit:12 years 1 month ago by Diesel Destroyer
Last edit: 12 years 1 month ago by Diesel Destroyer.
Posted 12 years 1 month ago #77680
The bushes arrived today...
The number on the Powerflex box is right.... But the bushes that arrived are for the lower arm.. 4x bushes and 2x sleeves... Not the bushes for the control arm..not amused..
It would appear the number of the item on the DCPerformance web site is incorrect... IE PFR42-220 is lower arm bushes..
Have e mailed them to see what is going on..
Would advise no one else order until they sort the numbers out
Replied by PQD44 on topic Re: MGF Rear Track Control Arm - How To
Posted 12 years 1 month ago #77681
:( Ouch :pinch:
That is not good news :nonod:
Look forward to hearing the reply and hopefully they can get you a set asap
Posted 12 years 1 month ago #77683
I reckon the PFR42-220 is the lower arm...
And no one makes poly bushes for the 2 joints that I have now destroyed..
Not looking good... And wasted £40 on bushes I don't need...
Should of stayed in bed today
Posted 12 years 1 month ago #77684
I've e mailed Powerflex direct now..
To ask if they don't do them... Can they do them?
Time to create page: 1.492 seconds
