MGF upgrades/ options
- Diesel Destroyer
What can I do to my F to make it drive/ handle better?
There are lots of options when it comes to modding your F
I intend to outline some of the other mods other than flashy lights or shines bits
Steering
The steering rack from a TF fits the F but has a closer ratio, so faster response. If you are dropping the front subframe then consider an upgrade whist it's out.
Suspension
The F has 4x spheres which are linked front and rear, 2 on the left paired, 2x on the right paired
If you discard the pipes that link them you can fit valves directly to each sphere. This improves the handling, Mike Williams Racing sell kits and brand new valves
Poly bushes have less flex than stock rubber, so again a whole vehicle poly bush upgrade will improve handling
Updated shocks will also help on the handling front, but fitting shocks that are really stiff can crackle pilot welds at the top of the shock towers. Common practise is to seam weld these for extra strength
Personally if intend to fit updated shocks I would fit 13.9 bolts in the lower mounts as that bolt can fail if replaced with a 8.8
The drop links (the bits that connect the anti roll bars to the hubs) are rather weak on the back and can snap.. There are slightly better ones on E bay. The fronts seam to fair better
The anti roll bars themselves are ok.. But coil springs UK now make updated ones to order (80% stiffer)
Vehicle handling solutions sell a 3 strut set which will stiffen up your F's body shell, this is about a days work to install but it will stiffen up the shell to improve handling
The subframes can be seam welded to stiffen them, improving handling, or Brown and Gammons sell seam welded ones new (race/competition subframes)
Rubbered subframe mounts can be replaced with the solid items from the TF or Vehicle Handling Solutions sell new sets
Mike Satur sells lowering pins to drop your F 30mm... The lower the centre of gravity the better it will corner
The lower engine mount on early F's fail due to spot welding the mount, Elise parts sell new updated mounts, motobuild sell a 'torque tamer' bush kit which will limit the twist of the engine under hard acceleration
Brakes
The brake servo moves a lot under hard braking, Brown and Gammons make a bracket which will help minimise of flex and improve pedal feel, stainless brake lines will help too and for any F which is used on the track a lot consider changing to DOT 5.1 fluid
Clutch
The clutch arm is a common problem too... If at any point you replace the clutch then replace the arm with a greasable item from Mike Satur and then grease every 3 months
Regular checks
Top arms need to be checked for wear and grease
Wheel bearings that are failing can give eratic handling and should be checked once a month.. jack the car up and wiggle wheel
The upper ball joints front and rear are cheap and wear will reduce handling, consider replacing annually to keep handling at its optimum
Other mods
VHS offer a service of lowering our seat base by 20mm, this will lower your centre of gravity and will improve the driving position
Steering
Suspension
Brakes
Clutch
Regular checks
Other mods
Last Edit:12 years 3 months ago
by Diesel Destroyer
Last edit: 12 years 3 months ago by Diesel Destroyer.
- a Guest
- Visitor
Great stuff Alan ..
More for your to do list for me
