Fit Alloy Instrument Dial Rings
fast jan wrote: You may have them fitted inside out, but at least you fitted them from the rear of the binnacle - not that anyone would be silly enough to have removed the clear plastic and fitted from the front of course... :whistle:
:dry: :lol:
http://www.the-t-bar.com/en/forum/9-mgf-tf-pitstop/87799-instument-alloy-clock-rings?limitstart=0
I will investigate and take things steady. It appears if I dont fully push em on and use a bit of sealant they will probably be OK
Did I listen to the more experienced mg people NO so it serves me right I have two little issues but hey ho I can try again . Like others have said the temp + petrol needles stick a bit as they are tight so there's 2 options. 1 shorten the back of the needles 2 file a bit of metal off dunno which I'm going for yet
But at least if someone tries to nick it they won't get far and won't know about HGF lol :woohoo:
This is the problem in a bit.more detail see how the back of the needle sticks on the alloy ring
- pendle lass
Replied by pendle lass on topic Fit Alloy Instrument Dial Rings
Posted 11 years 6 months ago #115879i think they look great though
Mine caught for a while. But have found they started to move ok after a while, not sure why.... How would you shorten the needle? What best way to do this Ben?
bensewell wrote: Precise hands ans dremmel cutting wheel I'm going to file a bit off the metal to push the lot a bit righter and then it should clear the movement
May be worth leaving a while to see if yours move like mine? Save you filing?
