Fit Alloy Instrument Dial Rings
Replied by John and Sue on topic Fit Alloy Instrument Dial Rings
Posted 11 years 6 months ago #116098
How many BHP do they add?
As much as a Magic Tree?
More?
I thought I was leading you along the Path of Purity of Form ,
My Son..... :P
If you're going to fit blingy non-functional [strike]crap[/strike] stuff, try and get it the right road round at least. :yesnod:
Replied by Baytown on topic Re:Fit Alloy Instrument Dial Rings
Posted 10 years 11 months ago #136188
I've just done this mod but forgot I'd read this thread a month plus back.. I tried prising the instrument cover off and cracked it a little. I don't think it will be an issue. The issue I do have is the temp needle fell out, and I'm buggered if I can get it to seat properly in the little white nipple that it sits in. My eyes can't see if the shaft on the needle and the nipple in the instrument have a flat which needs to match up to allow the needle to push in and seat correctly..
Any suggestions are very welcome as I'm hoping I haven't mucked my temp gauge up. I'm sure I didn't touch it.
Merry Christmas everyone.
Ken
by Baytown
Replied by David Aiketgate on topic Re:Fit Alloy Instrument Dial Rings
Posted 10 years 11 months ago #136196
From memory there is no notch to align, but the original needles were very tightly stuck on the rotating pin and I snapped one trying to fit my illuminated needles. The original pin is dark grey(normal bare metal colour), so it's possible you have a bodged pin if it's white.
When I fitted the illuminated ones the needles wouldn't stay put on the pins and I had to use a little glue on the shaft of the temp and fuel gauge to get them to seat. It was a question of getting the car up to temp and pushing the temp. needle on in the right position.
Same with the fuel, fill the tank and then fit the needle at Full.
Posted 10 years 11 months ago #136197
edit just re read your post and I know what you mean now there is a little white bump on the gauge with the locating hole for the pin. There is no notch but they are damn tight. Also check that the pin hasn't snapped, leaving part in the hole.
Posted 10 years 11 months ago #136229
Thanks David. Maybe some Super Glue might be the fix for this. The needle has approx 3 to 4 mm of shaft attached, but when I insert it into the little white nib, the temp needle sits very sloppy and isn't firm in its mount at all.
Can the temp gauge instrument be easily swapped over in the cluster?
Merry Christmas fellas.
Ken
by Baytown
Posted 10 years 11 months ago #136237
Yep two screws through the back, one or two screws(can't remember which) throught the clear plastic backing behind the face. The face is glued to the plastic backing.
Replied by Baytown on topic Fit Alloy Instrument Dial Rings
Posted 10 years 11 months ago #136252
Thanks David, good on you!
Now just to find a donor instrument cluster. I've emailed a seller on UK EBay to see if he will send a complete late model MGTF instrument cluster to me in Australia. I can relace the minor crack in the perspex as well while I'm at it. :bang:
Merry Christmas all.
Ken
by Baytown
Replied by David Aiketgate on topic Fit Alloy Instrument Dial Rings
Posted 10 years 11 months ago #136257
Check out this how to for photos.
There are actually three screws through the back and two on the front.
The small gauges are the same on mk1 and mk2/TF instrument packs, but the outer clear plastic cover is unique on each type of pack.
Last Edit:10 years 11 months ago by David Aiketgate
Last edit: 10 years 11 months ago by David Aiketgate.
Time to create page: 0.528 seconds
