Daylight Running Lights - how to fit
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /var/www/vhosts/the-t-bar.com/httpdocs/libraries/kunena/src/BBCode/KunenaBBCode.php on line 304. Please enable debug mode for more information.
Replied by Blow-in on topic Daylight Running Lights - how to fit
Posted 11 years 5 months ago #120175I would have preferred to mount them a bit more out board but the curve of the bumper would have had them pointing significantly side ways which is not ideal
Now for the wiring.
I secured the relay unit to the fuse box bolt:
The sidelight cut out wire is connected to the red & black lighting wire:
I use these Tap It connectors where access it tight - not to be confused with scotchloks!:
The earth was connected to the adjacent wiring box that bolts in to the wing.
The power lead was a bit more difficult. It needs to be a source controlled by position 2 on the ignition switch. I decided to go for a feed from the fuse box by the driver's knees.
The cable (in the grey conduit) runs through this grommet:
The power comes from the yellow feed in the fuse box below the steering wheel - this comes on with the ignition key at '2':
This is the finished job - more visible in real life:
Richard
Replied by David Aiketgate on topic Daylight Running Lights - how to fit
Posted 11 years 5 months ago #120177David
- Leigh Ping
Replied by Leigh Ping on topic Daylight Running Lights - how to fit
Posted 11 years 5 months ago #120198LIGHTING
Bulb List - Bulb locations and types.
Bulb Number Plate Lights - Replacement guide.
Bulb Side Repeater - Replacement guide.
Broken MGF front indicator clip fix - Repair Mod.
Daylight Running Lights - MGF - DRL, MGF Light Mod.
Headlamp - Dipped Beam Headlight Bulb Changing - Headlamp - Headlight Bulb changing - MGTF H7 55W Bulb.
Headlamp - Main Beam Headlight Bulb Changing - Headlamp - Headlight Bulb changing - MGTF HB3a 60W Bulb.
Headlights - Improvement guide.
Headlights - Trophy headlight type Painting guide.
Improving instrument display illumination - Visible light upgrade.
Instrument Cluster Warning Lights - Display guide.
Instrument Cluster - Illuminated Needles - Fitting guide.
Light and wiper stalk upgrade using Rover 800/Freelander control stalks - Fitting guide.
Lights Interior LED - Fitting guide.
Rear Lamp Protectors - Fitting guide.
Sidelight Bulb Changing Guide - MGF Sidelight change and upgrade guide.
Sidelight Bulb Changing Guide - MGTF Sidelight change and upgrade guide.
Tail light bulb upgrade - MGTF Tail light change and upgrade guide.
Replied by Baytown on topic Re:Daylight Running Lights - how to fit
Posted 10 years 9 months ago #138065I need to fit round Osrams to my TF 160 but they wont fit in the OEM fog light position without major mods.
Nice job either way.
Ken
Posted 10 years 9 months ago #138074The units were a good interference fit so I bedded them in with white Sikaflex 291 (the marine stuff which I have for the boat - rather like Loctite, not all Sikaflex is the same). They've not shifted at all and we also have some rough roads.
Richard
- Fatbaldingoldgit
Replied by Fatbaldingoldgit on topic Daylight Running Lights - how to fit
Posted 10 years 9 months ago #138078Looks like the original listing is no more though.
I think these are the ones..?
- Frank Zappa
Posted 10 years 9 months ago #138083Fatbaldingoldgit wrote: Great How-to Richard...am looking to do something similar with my LE500..
Yes, I've just checked the invoice and this was the supplier of my kit and the one you've linked looks the same.
Richard
