Volume valve exhaust.
Volume valve exhaust. was created by Attila
Posted 11 years 3 months ago #125020
Hello Guys
If some1 knows where to find this exhaust valve disconnecting thing on a reg 2005 car pls let me know.
Im lost cant find it.
thx.
by Attila
Replied by bensewell on topic Volume valve exhaust.
Posted 11 years 3 months ago #125022
Yes if you look under the drivers side rear bumper you'll see a circle metal valve thing with a little black hose / vacume clip on it. Thats it. Block it off and tie it out of the way then you get double the zorts output.
Replied by Badger on topic Volume valve exhaust.
Posted 11 years 3 months ago #125023
Hi Attila,
If you mean the Exhaust Volume Control Valve on a later TF then have a look at the hyperlink below.
http://www.mgf.ultimatemg.com/group2/exhaust/TF_evc.htm
Brian.
by Badger
Replied by Attila on topic Volume valve exhaust.
Posted 11 years 3 months ago #125025
cheers m8 but nothing there on the 2005 no canister nothing.
by Attila
Posted 11 years 3 months ago #125026
thx
i ll do it 2morrow.
TA
by Attila
Replied by John and Sue on topic Volume valve exhaust.
Posted 11 years 3 months ago #125027
Not fitted on later TF. Thats why you can't find it.
Lift the boot lid and on the right side there is a body lug with an 'ole in it. That's where the gubbins for the exhaust valve used to be located. Not fitted on the last cars: ours is a Feb 06 reg.
Replied by the singing bush on topic Re:Re: Volume valve exhaust.
Posted 11 years 3 months ago #125036
What John said :)
Other place to check is under the o/s rear of the car, on the exhaust if there is no diaphragm for the air pipe then you won't have it.
Its weird, the '04 TF I have now hasn't got one, my last '04 did have one and if I remember Ben's '53 reg TF doesn't have one...
Replied by Badger on topic Re:Re: Volume valve exhaust.
Posted 11 years 3 months ago #125037
May only be able to tell by VIN number as I also look after a Sept 04 160 TF for a guy at college which has one fitted, one of the first jobs we did was unplug the solenoid valve; "possibly sporadically fitted till the end of production!"
by Badger
Replied by bensewell on topic Re:Re: Volume valve exhaust.
Posted 11 years 3 months ago #125040
Both my 04 and 53 had it on. I swapped the OEM to xpower and then blocked the pipe up with a screw and a bit of gaffer / tie wrap combo.
Posted 11 years 3 months ago #125042
MG-R at their best eh..... Keeps us guessing :)
I know on my other 04 car I just unplugged it at the electrical plug end, the valve defaults to open when unplugged.
Replied by richandpaula on topic Volume valve exhaust.
Posted 11 years 2 months ago #127547
:help:
I would like both pipes working, rather than just the LHS one.
Could anyone have a quick look at ours on Saturday?
Posted 11 years 2 months ago #127550
I'll have a look Rich you can look at Bogey he has the pipe off dangling in the wind
The following user(s) said Thank You: richandpaula
