Hardtop wiring for an mgf
Hi all i have a hardtop for my f the wires to connect it to the heated window are there the heated screen but where should it be for the switch in the dash ?.
by p38
The plug will probably be pushed into the back of one of the switch blanks in the centre console.
You'll also need a relay to fit here.
It's where the black one is.
It's a standard automotive relay available everywhere.
Last Edit:11 years 3 weeks ago
by David Aiketgate
Last edit: 11 years 3 weeks ago by David Aiketgate.
The wiring for the switch may also be taped up in the loom just behind the consol.
by talkingcars
If you can't find the switch plug behind the blanking plate then remove the passenger side console cover and it will be there somewhere.
by marmite2
Time to create page: 0.573 seconds
