Are mgf's electrics that complicated
Are mgf's electrics that complicated was created by Mac526
Posted 10 years 5 months ago #141021
I used to be an electrical engineer working on Sea King Helicopters. Compared to MGF electrics they are simple, or am I getting to old to learn new systems.......... ;)
by Mac526
Replied by Davem on topic Are mgf's electrics that complicated
Posted 10 years 5 months ago #141022
Never to old to learn. I don't think they would be to hard for you :nonod: :nonod:
http://www.mgfcar.de/schedules/index.htm
Also all the wiring diagrams are in the Rave manual
[IMG]ht[/img]
by Davem
The following user(s) said Thank You: Mac526
Replied by cjj on topic Are mgf's electrics that complicated
Posted 10 years 5 months ago #141025
Electrics is electrics.
Mind you, I have worked with a few "air" electricians in the Air Force and I can kind of understand. :woowoo:
Posted 10 years 5 months ago #141029
:bust: :bust:
If you get stuck this might help :bust: :bust: :bust:
(just kidding of course you should never use anything but the rated fuse)
[IMG]ht[/img]
Last Edit:10 years 5 months ago by Davem
Last edit: 10 years 5 months ago by Davem.
Replied by Rich in Vancouver on topic Are mgf's electrics that complicated
Posted 10 years 5 months ago #141047
They started building the Sea King back in the days of the MGA so I'm not surprised that the MGF seems a bit different!
Fortunately, other than the computerized module bits the F's electrical is pretty durable and other than the usual corroded grounds and the infamous boot hinge wiring there aren't a lot of things that give trouble. It's very much a modern car in that it is usually a matter of figuring out which part is faulty and replacing it.
Replied by Mac526 on topic Are mgf's electrics that complicated
Posted 10 years 5 months ago #141086
That's what I stuck on, figuring it out!!!!!! Both my door windows stopped working at the same time, I have checked all the fuses ( not just the ones associated with the windows), I have replaced the yellow relay (R1) under the steering wheel. going to look at the earth points next, any idea where they are, or other suggestions?
by Mac526
Replied by talkingcars on topic Are mgf's electrics that complicated
Posted 10 years 5 months ago #141122
Mac526 wrote: That's what I stuck on, figuring it out!!!!!! Both my door windows stopped working at the same time, I have checked all the fuses ( not just the ones associated with the windows), I have replaced the yellow relay (R1) under the steering wheel. going to look at the earth points next, any idea where they are, or other suggestions?
Depends on the age of the car, some have BCUs, others have SCU's.
Posted 10 years 5 months ago #141141
Its a 1995, number 1738 of the production line... Thinking of getting an OBD reader to pug into it to run on my Iphone Take it this would be an OBD and not the BD2?
by Mac526
Replied by carlvk on topic Are mgf's electrics that complicated
Posted 10 years 5 months ago #141202
I'm not sure that the bluetooth odb readers work on mems 1.9.
mine certainly wont talk to my '97 F but is very happy with my '04 diesel Yaris.You may need a t300 or t4 test book
I would start at the window motor and work back
I.E if I apply 12 volts to the motor direct does it move>...... then check for voltage on the plug adaptor with a multimeter then the relay then the switch. Nowt wrong with working the other way of course
by carlvk
  • Bertl
  • in the middle of the midlife crisis
Replied by Bertl on topic Are mgf's electrics that complicated
Posted 10 years 5 months ago #141204
the magical number is 522573, from this VIN on all Fs were equipped with the MEMS3 engine control unit which is fully OBD-II compliant.
Your F should have a mechanical miles counter and will not be OBD2 compliant. It will have the same shape socket in the same place but is wired differently so will require a T4 computer.
as ever,
Rob
Last Edit:10 years 5 months ago by Bertl
Last edit: 10 years 5 months ago by Bertl.
Posted 10 years 5 months ago #141215
Thanks for all your help got the problem sorted. Disconnected the fuse box from harness and removed the MFU, cleaned all the terminals and re-assembled. Hey presto all working again, think it was slight corrosion on the terminals. the last part of my VIN is 001738 so looks like OBD2 not going to work...... :woo2: :woohoo:
by Mac526
Posted 10 years 5 months ago #141234
Good work. We tend to forget that terminals sitting for decades can corrode out of sight.
By the way, is 526 what I think it is?
Time to create page: 0.558 seconds
