Are mgf's electrics that complicated
http://www.mgfcar.de/schedules/index.htm
Also all the wiring diagrams are in the Rave manual
Mind you, I have worked with a few "air" electricians in the Air Force and I can kind of understand. :woowoo:
If you get stuck this might help :bust: :bust: :bust:
(just kidding of course you should never use anything but the rated fuse)
- Rich in Vancouver
Replied by Rich in Vancouver on topic Are mgf's electrics that complicated
Posted 10 years 5 months ago #141047Fortunately, other than the computerized module bits the F's electrical is pretty durable and other than the usual corroded grounds and the infamous boot hinge wiring there aren't a lot of things that give trouble. It's very much a modern car in that it is usually a matter of figuring out which part is faulty and replacing it.
Replied by Mac526 on topic Are mgf's electrics that complicated
Posted 10 years 5 months ago #141086Please Log in or Create an account to join the conversation.
- Online
Replied by talkingcars on topic Are mgf's electrics that complicated
Posted 10 years 5 months ago #141122Mac526 wrote: That's what I stuck on, figuring it out!!!!!! Both my door windows stopped working at the same time, I have checked all the fuses ( not just the ones associated with the windows), I have replaced the yellow relay (R1) under the steering wheel. going to look at the earth points next, any idea where they are, or other suggestions?
Depends on the age of the car, some have BCUs, others have SCU's.
Posted 10 years 5 months ago #141141Please Log in or Create an account to join the conversation.
Replied by carlvk on topic Are mgf's electrics that complicated
Posted 10 years 5 months ago #141202mine certainly wont talk to my '97 F but is very happy with my '04 diesel Yaris.You may need a t300 or t4 test book
I would start at the window motor and work back
I.E if I apply 12 volts to the motor direct does it move>...... then check for voltage on the plug adaptor with a multimeter then the relay then the switch. Nowt wrong with working the other way of course
Your F should have a mechanical miles counter and will not be OBD2 compliant. It will have the same shape socket in the same place but is wired differently so will require a T4 computer.
as ever,
Rob
Posted 10 years 5 months ago #141215Please Log in or Create an account to join the conversation.
By the way, is 526 what I think it is?
