Adjusting Alternator belt 04 160 with aircon
Adjusting Alternator belt 04 160 with aircon was created by Baytown
Posted 9 years 6 months ago #158937My set up doesn't look to much like Clives excellent how too on this simplish job.
For the life of me, I cant loosen the 10mm bolt on the adjuster pulley. What tool do you blokes use? No spanner I can find fits or gives enough purchase on the soft bolt head. Also, the bolts holding the Alternator in place are socket head, so bugger all room to use the relevant hex insert.
What a crap job! And I cant use the car until sorted as the belt is screaming.
Let's not even talk about me tearing the rt hand corner of the rear bumper away from the car bottoming out getting into my garage. (Shit plastic mounting point) Not a happy boy.
Thanks for any help, suggestions fellas.
Ken
Replied by mgbv8mike on topic Adjusting Alternator belt 04 160 with aircon
Posted 9 years 6 months ago #158942When I fitted aircon to my TF160, I used an allen key to tackle the socket heads.
You could try talcum powder on the belt , it might stop the squeek long benough to get the car to a garage.
Good luck.
Mike
Replied by helsbyman on topic Adjusting Alternator belt 04 160 with aircon
Posted 9 years 6 months ago #158944BILSTIEN DAMPERS, 4-2-1 MANIFOLD, HEAD WORK BY SABRE.
Posted 9 years 6 months ago #158947http://www.mgfcar.de/alternator/belt_tension_MGF.htm
Replied by Baytown on topic Re:Adjusting Alternator belt 04 160 with aircon
Posted 9 years 6 months ago #158950Ive gone in from the top after removing the hard top and engine cover. There was no way you can access the alternator from below. Ive loosened it off and will see if I can pry it a little to tighten the belt a smidgin. The tensioner pulley 10 mm bolt is a POS, made of cheese. Very poor access and strips if you look at it tersely. I cant undo it or the bolt will fail.
The belt has some minor cracks in it even though it is only 2 years and 20,000km old.
Ill put it all back together and get the pro' at Hypertune Cairns to replace it next service.
Again, what a mongrel of a what should be a simple job!
Best wishes all.
Ken
- Fatbaldingoldgit
Replied by Fatbaldingoldgit on topic Adjusting Alternator belt 04 160 with aircon
Posted 9 years 6 months ago #158951"You can’t be a real country unless you have a beer and an airline – it helps if you have some kind of football team, or some nuclear weapons but at the very least you need a beer"
- Frank Zappa
Posted 9 years 6 months ago #159001To top it off, now there is no charge from the alternator. Belt isnt slipping, but battery light illuminated, and no charge on the multimeter. Battery was charged fully over night.
I did spark the alternator once when tightening it back up. ( have never had to disconnect a battery when tightening belts before. MGTF lesson learnt)
Question: is there an alternator fuse?
If its fried, what exactly fails on the alternator as its mechanical,spins and generates current. I cant see what would fail?
Thanks every one, looks like its off to the specialists.
Ken
Posted 9 years 6 months ago #159005Please Log in or Create an account to join the conversation.
Posted 9 years 6 months ago #159007Ken
Posted 9 years 6 months ago #159086Thank-you mate. You learn something every day eh!
Best wishes.
Ken
Are you sure? an alternator will cook a 40 amp fuse in no time!mgbv8mike wrote: My fuseholder says max 70 amp, but it's only got a 40 amp one in...so you may have gone a bit overboard on that one !
I suspect your mixing the memory of the 70 amp fuse holder with the 40 amp fuse that is for the EPAS, which is found under the bonnet (front of car) near the fuse box, with the 80 amp charging system fuse which is found in the engine bay on the bulkhead
