i see the light!... erm actually, no i don't help!
Replied by David Aiketgate on topic i see the light!... erm actually, no i don't help!
Posted 14 years 11 months ago #5331No, the 'Trophy' conversion does not affect the light output. The part painted has no part in the production of the light beam.Polo;5329 wrote: I hope I have not made matters worse by doing the Trophy headlight conversion too..!!
Replied by polo on topic i see the light!... erm actually, no i don't help!
Posted 14 years 11 months ago #5339David Aiketgate;5331 wrote: No, the 'Trophy' conversion does not affect the light output. The part painted has no part in the production of the light beam.
Phew - thanks for that David.
By twin and single headlight are you referring to the 2 lights in 1 on the MGF? Is it usual to have seperate lights like this?
PS - what use do the sidelights play? they are so ineffectual..!!
Posted 14 years 11 months ago #5340Yep the MGF are two in one(twin) Up until projector headlights it was usual to have either a single headlamp with a dual filament bulb(dip/main) This allowed for a bigger/ more efficient reflector, or a twin setup of separate main and dip like the F. The TF projector type headlamps was supposed to solve the F problem.Polo;5339 wrote: Phew - thanks for that David.
Sidelights - good question. I believe that the original use was to illuminate the car when parked. Not as some people think, to use when driving around when it's not dark enough for headlamps, or for in fog!
Posted 14 years 11 months ago #5341David Aiketgate;5340 wrote: Yep the MGF are two in one(twin) Up until projector headlights it was usual to have either a single headlamp with a dual filament bulb(dip/main) This allowed for a bigger/ more efficient reflector, or a twin setup of separate main and dip like the F. The TF projector type headlamps was supposed to solve the F problem.
David - if you are confused what chance do us mere mortals have?
Replied by cjj on topic i see the light!... erm actually, no i don't help!
Posted 14 years 11 months ago #5346I honestly don't think that you should be able to drive on side lights nowadays. As soon as you start yor engine your sidelights should go to dipped beam.
