Handbreak problem and fuel cap problem!
Handbreak problem and fuel cap problem! was created by Adam-Mgtf
Posted 14 years 11 months ago #5305
hey guys, just got a message on capri power forums about a members parents TF's hand break (what a mouth full)
the guy is having trouble tightening up a loose hand-break as he can't seem to get a spanner into where the tightening nut is under the center cubby, am i right in recommending a small ratchet? if i remember rightly thats how i did it?
he's saying that the handbreak light keeps popping on but im assuming this is because the leaver is slack? im pretty sure mine did this before i tightened it?
anyway im sure i managed that problem myself however he has another that im stumped on
"also weve got a bad problem with petrol comming out of the filler cap. we filled it up one day and it poured out stripping the paint off the side of the car :-( any ideas?"
im guessing the seal is broken on their fuel cap and simply replacing the paetrol cap with one that doesnt have a broken seal on it would fix this problem?
Replied by adamelphick on topic Handbreak problem and fuel cap problem!
Posted 14 years 11 months ago #5308
Adam-MGTF;5305 wrote: hey guys, just got a message on capri power forums about a members parents TF's hand break (what a mouth full)
Handbrake sounds about the right solution - although they do want to investigate WHY it needs so much tightening - maybe seized levers?
The petrol cap must have a very bad seal to let that much petrol out that it strips paint.... i guess it's possible though! I'd suggest to them not to fill to the brim till sorted.
Replied by Adam-Mgtf on topic Handbreak problem and fuel cap problem!
Posted 14 years 11 months ago #5309
AdamElphick;5308 wrote: Handbrake sounds about the right solution - although they do want to investigate WHY it needs so much tightening - maybe seized levers?
good tip on checking for seized leavers.... im guessing a replacment cap is needed? any way to get one that doesnt involve having a differant key to the one the car allready has?
Posted 14 years 11 months ago #5319
Adam-MGTF;5309 wrote: good tip on checking for seized leavers.... im guessing a replacment cap is needed? any way to get one that doesnt involve having a differant key to the one the car allready has?
Fairly sure you can get the cap apart with a bit on manoeuvring - then swap the barrels.
Posted 14 years 11 months ago #5420
AdamElphick;5319 wrote: Fairly sure you can get the cap apart with a bit on manoeuvring - then swap the barrels.
:o why didnt i think about that
