MG T-Bar Quiz
Posted 12 years 1 month ago #76430
Half right Paul.
8G is an A-Series Gold Seal/Silver Seal (reconditioned) engine
84G is a B-Series Gold Seal/Silver Seal engine
So the codes would denote a "Gold Seal" or "Silver Seal" reconditioned engine had been fitted
http://www.british-cars.net/mg-midget-sprite-technical-bbs/engine-numbers-2010020210460413807.htm
Last Edit:12 years 1 month ago by cjmillsnun
Last edit: 12 years 1 month ago by cjmillsnun.
Replied by groovylee on topic Re: MG T-Bar Quiz
Posted 12 years 1 month ago #76432
Also half right CJ, my names Lee :lol:
although i'm sure you're right, this is what I found:
1956 to 1970 'A', 'B', and 'C' Series engine Prefix
The 'BP' prefix was dropped once BMC had its three engine types, A, B, and C. Again, there is a prefix, consisting of a number, then letter/letter/letter, then the engine number.
Cubic capacity Make Type Ancillaries Compression
8 803cc B BMC Industrial A to Z A automatic H high comp
9 948cc G M.G. ,, M manumatic clutch L low comp
10 1098cc A Austin ,, P police spec.
12 1200cc W Wolseley ,, U central gear change
12 1275cc H miscellaneous ,, N column change
15 1489cc J Commercial ,, O overdrive
16 1588cc V Van den Plas ,,
16 1622cc M Morris ,,
18 1798cc R Riley ,,
taken from:
http://mgaguru.com/mgtech/engine/be100.htm
but then it does make reference to the 8G furhter down the page. :broon:
Posted 12 years 1 month ago #76433
pants, i think i just missed some irony :slapme:
Posted 12 years 1 month ago #76434
Correct the reference is to the Gold Seal replacement engines. However, although the source I was looking at says 84G and in fact 86G for the C Series, I seem to recall 48G also being mentioned by other MGB owners. My source is Neil Cairns' guide. The B Series in factory numbering would have been 18G for the MGB starting with 18GA going to 18GK and then 18V.
Needless to say though , next question please! I guess in fairness cj was closer but fight amongst yourselves as to who sets the next question.
by MartinW
Posted 12 years 1 month ago #76435
you go for it CJ, i'll have a stab at the next one :broon:
Posted 12 years 1 month ago #76505
When launched in 1985, the MG Montego Turbo was a very conventional car in pretty much every way.
However one aspect was unusual and that was down to the French.
What was it?
Posted 12 years 1 month ago #76575
was it the talking dashboard? i knew about it, but had to google who came up with the idea, and found out some interesting things that i didn't know. the talking dash was first utilised by the french on the renault 11, some two months before MG did. also that nicolette Mackenzie did the voice :broon:
any good?
Last Edit:12 years 1 month ago by groovylee
Last edit: 12 years 1 month ago by groovylee.
Posted 12 years 1 month ago #76578
Nope.
The Monty Turbo had analogue instruments.
The first MG Maestros and a very few MG Montego EFis had solid state instruments.
It was something far more fundamental. Also some Metros had something similar but provided by a British manufacturer.
Posted 12 years 1 month ago #76582
hmmmmmmm. *shuffles off with head down muttering under his breath*
Posted 12 years 1 month ago #76616
Well, if you overlook the use of a turbocharger, which wasn't particularly conventional on a family saloon, I presume you are referring to the use of metric wheels?
88 MG Metro Turbo
72 MGBGT: Project Speed 6 MGB
by MG mad
The following user(s) said Thank You: cjmillsnun
Posted 12 years 1 month ago #76617
I am indeed.
Turbos weren't very conventional, but were not unheard of by '85. The SAAB 99 turbo having been introduced in 1972!
But in a family saloon, the Michelin TDX system was very unusual, as was the fact it was a metric size, 365mm diameter wheels which is 14.37"
The Michelin TDX system was also unusual in that it had 2 grooves on the rim and the bead sat between the grooves and the edge of the rim. The idea was that the tyre could totally deflate/blowout (the TD part of TDX) but the tyre remain on the rim for long enough to bring the car to a controlled stop at the side of the road. Needless to say I never tested it. The only issue was tyre availability. With it being such an unusual size, the fact only Michelin made them, and that Montego Turbos weren't over common, finding them was hard, and when you did they were very expensive. About £140 per tyre in 1989! It explains why MGF wheels find there way onto Maestros and Montegos.
A similar system was fitted to the Metro but the tyres for that were made by Dunlop
Posted 12 years 1 month ago #76621
damn! i found the bit about the 'run flat' tyres, but never twigged they were michelin :slapme:
nice one MGmad :broon:
Time to create page: 0.681 seconds
