clocks grrrrrrr
clocks grrrrrrr was created by Adam-Mgtf
Posted 14 years 11 months ago #5726
so im having some "issues" with my clocks
i CANNOT get the speed right and the rev counter is sticking and wont hit the rev limit properly... the fuel gauge doesnt work and either i have HGF or the water temp is buggered too....
so im thinking theres something wrong
any idea's??? i think it may be because the clocks im using are off a 1.8? (non vvc)
Replied by cjj on topic clocks grrrrrrr
Posted 14 years 11 months ago #5730
No idea. Not sure if the speed feed from the ECU would be the same.
Could it not all be down to badly fitted needles?
Another possibility is a duff power stabiliser, but I'm not sure what these use and whether they even share the same supply.
Replied by Adam-Mgtf on topic clocks grrrrrrr
Posted 14 years 11 months ago #5733
CJJ;5730 wrote: No idea. Not sure if the speed feed from the ECU would be the same.
i didnt understand all that... but no matter what i do with the needles it's just not working :mad:
edit: im thinking maby if the gearbox is different on the 1.8 (which i think it is as the clutch is different) and the gear ratios are different (which they are) then surely the speedo would be off wouldn't it? or am i trying to be too clever?
Posted 14 years 11 months ago #5741
Yep, if the gear ratios are different it might read wrong. But then again, I think it is on the final drive, so maybe not. :dunno:
Hope that helps. :dunno:
Replied by jonnocash on topic clocks grrrrrrr
Posted 14 years 11 months ago #5755
Adam-MGTF;5726 wrote: so im having some "issues" with my clocks
dont worry to much those speed signs are just advisories, when the car stops pulling change gear. my fuel guage works but i still ran out of fuel today - iwould try and sort the water temp though
Replied by mgfmad on topic clocks grrrrrrr
Posted 14 years 11 months ago #5758
Sounds like there is a problem with the whole clock set as you have a number of problems - If it was just and incorrect speed reading then its likely just down to the different ratios.
Have the clock been OK before and suddenly developed a problem or is this a set that you have fitted?
MG TF LE500 27 of 500
by mgfmad
Posted 14 years 11 months ago #5773
MGFmad;5758 wrote: Sounds like there is a problem with the whole clock set as you have a number of problems - If it was just and incorrect speed reading then its likely just down to the different ratios.
the clocks are off MGF n TF bitz so no idea if there is problems with them... i could try using my old ones again but i have no idea if i broke them somwhere along the line as i took them apart erm... enthusiastically
Posted 14 years 11 months ago #5805
Might be best to swap them over again - then you will know if the fault lies with the replacement set
by mgfmad
Posted 14 years 11 months ago #5807
MGFmad;5805 wrote: Might be best to swap them over again - then you will know if the fault lies with the replacement set
this i shall do and report back
Posted 14 years 11 months ago #5819
Have you done it yet? :dunno: :)
Posted 14 years 11 months ago #5843
CJJ;5819 wrote: Have you done it yet? :dunno: :)
well i was gonna, and erm then i got lazyitess, i may do it tonight i can't decide lol
Posted 14 years 11 months ago #5854
I've been suffering from that for a while. So many projects, so little enthusiasm. I blame the rain/snow/wind/cold/dark (delete as appopriate). :)
Time to create page: 0.519 seconds
