Body Bracing Kit
Body Bracing Kit was created by Auseff
Posted 12 years 4 months ago #58047
A few years ago I purchased ex the UK a bracing kit for the MG-F. Cant remember where from though. For reasons aplenty I've never gotten around to fitting it. It consist of:-
An under dash brace bar (which needed the dash removed which is probably why the kit is still in the workshop.
A rear engine bay brace.
An under body cross brace, more or less a giant X.
I believe this kit was fitted to the last Fs built after the Chinese took over. Does anyone have any experience with a car thus fitted? Is there any noticeable improvement? The engine bay and underbody bracing is easy enough to fit but the under dash is by definition difficult. I am toying with fitting the other two braces and leaving the under dash until I've reason to pull the console out for whatever reason may arrive.....
Cheers - Murray A.
by Auseff
Replied by Leigh Ping on topic Re: Body Bracing Kit
Posted 12 years 4 months ago #58051
Is the brace like this Auseff?
I noticed some wallow when I inadvertently left it disconnected (I thought that I might have broken an engine mount at the time because of it). Finding the schoolboy error I reconnected it and it showed the difference immediately. So, yes, it does make a big difference. I find the driving stability in my TF is solid.. so far. :)
Replied by Yellow Peril on topic Re: Body Bracing Kit
Posted 12 years 4 months ago #58052
Talked yourself into this one Leigh.
Take them off get some made [in stainless] I will have a go. being the heaviest MGF'er.
I did note Daz, did make a comment on the front subframes re: a cross under it,
I thought then t'was a good idea, [me like safe side or justins]
Last Edit:12 years 4 months ago by Yellow Peril
Last edit: 12 years 4 months ago by Yellow Peril. Reason: brain works slower in mornings
Posted 12 years 4 months ago #58067
Yellow Peril wrote: I did note Daz, did make a comment on the front subframes re: a cross under it,
Aah I see now.. Like this one?
Pic courtesy of 'Cavaddict' (Steve) over at 'The MGF Register'. He's doing a great rebuild on a beautiful TF right now. It's well worth a look. :broon:
Last Edit:12 years 4 months ago by Leigh Ping
Last edit: 12 years 4 months ago by Leigh Ping. Reason: pic inserted.
Replied by Auseff on topic Re: Body Bracing Kit
Posted 12 years 4 months ago #58068
Yes thats the one.....
So you'd say that it makes a difference?
Do you have the under dash one fitted as well. Expect this would help eliminate scuttle shake.....
Murray A.
by Auseff
Posted 12 years 4 months ago #58073
yes, the cross, can't do any harm and should stiffen corner to corner significantly, Ken
Replied by Diesel Destroyer on topic Re: Body Bracing Kit
Posted 12 years 4 months ago #58109
The kit was designed to improve the torsional stiffness of the F.. a problem that was cured on the TF
The one behind the dash requires a welder.. to weld some tabs to the cross member to allow bolting in..
I personally have welded my front cross brace to the front subframe.. If you fit the cross member you should also fit solid subframe mounts too..
The boot ones can be fitted with drill and nuts/bolts.
Ive also made a pair of boot struts and one that goes under the bonnet to stiffen the shell further..
Torsional stiffness testing applied to a car before and after fitting the kit has proved it does make a difference..
VHS (vehicle handling solutions) still sell the kit, and they do come up on E bay now n then too..
Allan
The following user(s) said Thank You: Leigh Ping, Yellow Peril
  • Visitor
  • Visitor
Replied by a Guest on topic Re: Body Bracing Kit
Posted 12 years 4 months ago #58120
Is that the thing Andy had to stiffen his front end, and he is going to chrome :-?
Posted 12 years 4 months ago #58142
Jan the one Andy had is one I made for under the bonnet.. That bolts between the shock towers..
Next up Andy is getting boot struts, once I've made them
  • Visitor
  • Visitor
Posted 12 years 4 months ago #58144
Its going to look amazing once he has chromed it :broon:
Replied by Rich in Vancouver on topic Re: Body Bracing Kit
Posted 12 years 4 months ago #58150
Softly~Softly wrote: Is that the thing Andy had to stiffen his front end, and he is going to chrome :-?
Jan, Taken out of context your comments are priceless! :lol:
BTW: Here is the link for VHS: Vehicle Handling Solutions
Last Edit:12 years 4 months ago by Rich in Vancouver
Last edit: 12 years 4 months ago by Rich in Vancouver.
  • Visitor
  • Visitor
Posted 12 years 4 months ago #58154
:oops: Rich, nice to see I made you ~Grin~
Time to create page: 0.536 seconds
