Brake discs
http://cgi.ebay.co.uk/MG-TF-160-304mm-Front-Drilled-Grooved-Brake-Discs-02_W0QQitemZ110448415529QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item19b73d1329
Cant comment on how good they work yet but the service was excellent. I also fitted Greenstuff pads.
Slippy;6788 wrote: I got my drilled / grooved discs on ebay, paid a bit extra for them to have the anti rust coating on them (dunno how long it will last) obviously it wears off the friction surface.
Seems like quite a good price in all fairness. I'm toying with those that you've suggested or these: http://cgi.ebay.co.uk/MGF-MG-TF160BHP-MINTEX-FRONT-BRAKE-DISCS-304MM-AND-PADS_W0QQitemZ360069381698QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item53d5cebe42
Sam Luck;6793 wrote: I have bought the EBC Green stuff pads already for when I get my APs Mintex are good as well I was told.
Thanks Sam... I'm running on Red Stuff at the mo but they're almost worn out so might as well change them whilst replacing the discs.
- quicksilver
Its worth looking at both Black Diamond and Tarox disc if you fancy spending your pennies both will improve the braking performance, as would the Black diamond Carbon Ceramic pads, used them on the Nurburgring last August with no fade.Kara;6787 wrote: Thinking about investing in some new front discs as the braking is getting much more wobbly at high speeds. :frown: If I've got AP's fitted what are the options when it comes to discs? Will probably get greenstuffs as well.
Chris
- gotenks1321
I use Greenstuff on the rear and they're ok there though :yesnod:
Quicksilver;6965 wrote: Its worth looking at both Black Diamond and Tarox disc if you fancy spending your pennies both will improve the braking performance, as would the Black diamond Carbon Ceramic pads, used them on the Nurburgring last August with no fade.
Chris
Thanks for the recommendation I'll check them out.
gotenks1321;7109 wrote: I'd recommend Mintex pads over Greenstuff for the front if you do a lot of 'spirited' driving Disc wise, can't really recommend as I don't have the APs :shake:
Thanks Dan! Do Mintex come in different grades like greenstuff, redstuff etc.?
CJJ;7121 wrote: Makes my investment seem so much sweeter http://www.the-t-bar.com/showthread.php?t=576&highlight=discs
Show off! :prrr:
Well if you spot any more bargains like that then please let me know! :poke:
http://cgi.ebay.co.uk/ROTORDISC-ROVER-MGF-1-8-95-FRONT-GROOVED-BRAKE-DISCS_W0QQitemZ320456566789QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item4a9cb32805
CJJ;7125 wrote: Hold on....WTF are those??????
Weird I've never seen anything like them! They look pretty though. :yesnod:
Kara;7126 wrote: Weird I've never seen anything like them! They look pretty though. :yesnod:
Go on.......
