TF flat battery
TF flat battery was created by madmax
Posted 14 years 10 months ago #7267
Over the christmas period my tf suffered a flat battery i recharged it overnight disconnected from the car, The following day i reconnected the battery on trying to start the car all that happens is the engine runs for thirty seconds then stops, I have replaced the fob batteries but still no joy can anybody help.Car now fixed by Russell of MG Rover solutions the ECU had lost memory due to low volts in battery he reprogrammed the ECU and all is ok now.
by madmax
Replied by eagle on topic TF flat battery
Posted 14 years 10 months ago #7271
madmax;7267 wrote: Over the christmas period my tf suffered a flat battery i recharged it overnight disconnected from the car, The following day i reconnected the battery on trying to start the car all that happens is the engine runs for thirty seconds then stops, I have replaced the fob batteries but still no joy can anybody help.
Not sure if all MGF/TF have the same system, but my 160 TF needs to have the immobiliser resync`t if I disconnect the battery. Also You might need to resync the fob if you have removed those batteries as well. You should find the process explained in your manual.
However if you have managed to lock and unlock your car the fob resync looks to be not neccesary.
I wish
THe Lone Gunman
by eagle
Replied by Adam-Mgtf on topic TF flat battery
Posted 14 years 10 months ago #7303
i suppose if the battery was flat for some time it may of discharged? meaning it can only store a very small amount of charge (which the alternator cannot replace quickly enough after the car is started?)
educated guess that^ be warned lol
Time to create page: 0.498 seconds
