Coolant temperature sensor
- a Guest
- Visitor
http://cgi.ebay.co.uk/MGF-1-8i-Top-Quality-O-E-Water-Temperature-Sensor-95-02_W0QQitemZ150380388632QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item23035ea118
And I take it the sensor simply unscrews from where it's housed?
Cheers! :grouphug:
Yes, that's the one. Just unscrews as you say.:yesnod:thedigger;8752 wrote: Mine's failed so I either get no temperature reading (or a rubbish, fluctuating one between the bottom two notches on the dial). My sensor is black, do I need to replace like for like?
Cheers! :grouphug:
Are you sure it's the sensor? Have you checked the connections?
- a Guest
- Visitor
Will coolant fluid leak out when this is unscrewed (meaning I have to re-bleed the coolant system)
You will lose a little coolant, the amount will depend on how quick you are at swapping the sensors.thedigger;8789 wrote: The connections seem to be ok... I had the car in key position 2 and was watching the temperature gauge while I wiggled the connectors... didn't make any difference.
