What Pads Should I Use ?
What Pads Should I Use ? was created by Uncletone
Posted 11 years 8 months ago #106259
Hi Guys,
I've replaced the discs and pads all round on my "F" with std pads. And whilst this improved the braking its still pitiful, in fact on one excursion this week I was looking at using a farmers gate as additional braking .No ABS by the way. The problem is when you drive modern machinery these days with ABS, Brake Assist, Traction Control etc,and then you jump in the little "F" you forget that you need to adapt driving to suit. Frightening and sitting on a poultice comes to mind.
Anyway, as always I'm digressing. Without going to a bigger disc set-up, involving bigger wheels (15" to 16") new tyres calipers and more expense, the bank manager can't cope anymore, would changing the pads to something like EBC Green Stuff help.
Thanks as always guys for your comments they are really appreciated.
Tone
Replied by andywatson on topic What Pads Should I Use ?
Posted 11 years 8 months ago #106263
I'd probably go with Mintex 1144's rather than EBC. EBC are notorious for flaking.
If a jobs worth doing, it's worth overdoing
Replied by Uncletone on topic What Pads Should I Use ?
Posted 11 years 8 months ago #106264
Thanks Andy will these be OK for normal road use not neccessarily, shall we say spirited driving?
Posted 11 years 8 months ago #106269
The 1144's are classed as fast road, but will be fine for normal driving.
Replied by Jack of Hearts on topic What Pads Should I Use ?
Posted 11 years 8 months ago #106270
1144's will be fine for road use. They work from cold unlike EBC products
Replied by Kameleon on topic What Pads Should I Use ?
Posted 11 years 8 months ago #106272
Another vote for the 1144's - some will say they eat discs, which in effect I guess is true as they are a fast road pad. I do wonder though if these comments come from people that fitted 1144's with EuroCar part discs.
They'll be fine for road use as unlike the more aggressive Mintex compounds, these work well from cold. It's my ethos to always have more stopping power than you hope to ever need, this is why I have 1144's even though my TF is a daily drive. Stopping in 22 meters or 20 meters could be the difference of hitting a child who's run out into the road or not, I hope the 1144's give me 20 and not 22!
Posted 11 years 8 months ago #106273
Thanks for all your comments it looks like I'll be spending some money with Mike Satur or whoever sells them.
Good old internet.
Tone
Replied by Blow-in on topic What Pads Should I Use ?
Posted 11 years 8 months ago #106277
Tone,
the MGOC stock Mintex pads for £19.35 for a front set for a F....doesn't say what number they are but the MGOC can advise. A comparable green stuff kit is £56.50. The MGOC also stock a wide variety of discs including their own club grooved discs @ £89.95 a pair.
Richard
by Blow-in
Posted 11 years 8 months ago #106316
Thanks Richard for that info. I've put a call in, they aren't M1144's, but they reckon they're a good replacement for the std pads.
Thanks David, Amazon are doing them a few quid cheaper and no P&P. I notice how you were tempting me to spend more money by slipping that little item on the end. Brake Servo Brkt. I refused to look because you would have had me running off and buying one. Anyway there's nothing wrong with my servo, I've put a couple of heavy duty cable ties around it to stop it moving.
Tone
Posted 11 years 8 months ago #106322
i wouldnt worry, you cant buy a brake servo brace anyway. You have to make them
Replied by nick on topic What Pads Should I Use ?
Posted 11 years 8 months ago #106329
B&G do a brake servo bracket, see link below
http://www.brownandgammons.co.uk/product.aspx?CID=a6438a2a-06ce-45d6-a18f-943e9e1c4240&SID=c4feec96-671b-4087-b1b1-8163c24fafbc&PID=687d6b8b-d8d1-4cfc-8057-a7cd197aa4c9
Not easy to fit if you have aircon, but OK otherwise (apparently)
by nick
Time to create page: 1.730 seconds
