Replied by g7nbp on topic Wocha bin doin on your MG this week then?
Posted 6 years 6 months ago #185785Please Log in or Create an account to join the conversation.
- SundanceUK
Replied by SundanceUK on topic Wocha bin doin on your MG this week then?
Posted 6 years 6 months ago #185786Where did you take Bluey to be aligned, Mr Bluestreak? I have been looking for a good local garage who can do it. I need to get my car done soon, and the last two garage I used I was not happy with the results, and one said I had play in my steering rack, but after taking it out and replacing it, it looked fine to me!mgtfbluestreak wrote: Had car fully tracked.I had recently put a new upper balljoint on the passenger side rear....has you can see from the before measurements on this wheel the readings are in red.
Also, looking at the camber measurements, the camber is not adjustable on our cars, unless you have replaced the rear lower arms with adjustable ones.
Sundance
Replied by Fisher on topic Wocha bin doin on your MG this week then?
Posted 6 years 6 months ago #185787Fitted two (well one actually) new gear cable linkages, gear box end. It appears that one of them is too short, (both supplied was same size and only fitted one linkage, the horozontal one) so the original had to be put back until problem solved. Has anyone experience this and how did you overcome it?
Bought a set on nice leather seats and fitted.
- mgtfbluestreak
Posted 6 years 6 months ago #185788Please Log in or Create an account to join the conversation.
Posted 6 years 6 months ago #1858001) Removed a subframe mount through bolt - 5 hours! Removed remains of N/S hydragas pipe - 20 minutes
2) Fitted front to rear brake line - 20 minutes.
3) Rerouted clutch flexi hose - 10 minutes.
Posted 6 years 6 months ago #185802Please Log in or Create an account to join the conversation.
- Andy Lawrence
Replied by Andy Lawrence on topic Wocha bin doin on your MG this week then?
Posted 6 years 6 months ago #185805Whoever had the steering wheel off last :coat: had forgotten to clip the wiring plug in :spank: :slapme:
WHALE OIL BEEF HOOKED
- The driving dutchman
Replied by The driving dutchman on topic Re:Wocha bin doin on your MG this week then?
Posted 6 years 6 months ago #185810Verstuurd vanaf mijn SM-G920F met Tapatalk
Replied by stevew on topic Re:Wocha bin doin on your MG this week then?
Posted 6 years 6 months ago #185812My TF now has a great gear change and seems sweeter to drive. Thanks again to both of them.
Tomorrow is MOT time I'm hoping to get through without any advisories. Hoping, we'll wait and see :pop:
:beer: :beer: Steve.
Replied by G0RSQ on topic Wocha bin doin on your MG this week then?
Posted 6 years 6 months ago #185813Airportable wrote: One gratifying note however was that there was not the slightest sign of emulsion in the system, at all, nothing, no greasy spots, not a trace or suggestion & that on a 119k twenty year old K series MGf . And there are no leaks & it works properly & it didn't seem to take longer to heat up & if it helps ward off HGF, even a little, I'll be happy & I hope that's not pissed on the chips.
So why are you "modifying" something that has been operating perfectly for so long?
Posted 6 years 6 months ago #185817Please Log in or Create an account to join the conversation.
Posted 6 years 6 months ago #185818Investigation revealed this.
Clamp almost completely disintegrated.
Of course to fit a new one requires removing the flange and welding a new one back on.
So I took off the back box and had the welding done. All back together and no leaks!. Yeah!:clap:
