Replied by stevew on topic Wocha bin doin on your MG this week then?
Posted 6 years 5 months ago #186510
David Aiketgate wrote:
David Aiketgate wrote: In that warm weather we were having, I discovered that my heater was still blowing slightly warm on the cold setting.
Not a biggy, just needed to adjust the Bowden cable right?
Yep. I took off the driver's kick panel and loosened the cable clamp, adjusted it and refitted. When I went to refit the kick panel I had managed to lose one of the fixing screws!
Ah well, I just found a random black screw and refitted the panel.
Started the car and ran it up to temp to check the heater output. Yeah, blowing cold on cold and hot on hot!
Job's a good un, right?:broon:
Except...why is coolant dripping from the kick panel?
Yes, this total numpty had screwed that odd screw straight into the heater hose!:oops: :slapme: What a complete pillock! :slapme:
Well, Rimmer bros aren't the cheapest but they managed to get a new hose delivered by next day.
I've just completed the swap and all is good again..
I just want to say that who ever designed those spring hose clips should be dangled by one attached to his private parts over a pool of piranha!
What's wrong with jubilee clips ?
The top spring clip made a 30 minute job into a 3 hour marathon. :rant: It was aligned perfectly so that it was virtually impossible to get a tool on it!:bang:
You're right there David I've been changing a few of the coolant hoses. Mainly the ones in the engine compartment and trying to remove the spring clips was a nightmare of a job. Trying to get grips in between the engine and bulk head to remove the clips is certainly a test of anyone's patients.
:beer: :beer: Steve.
by stevew
Posted 6 years 5 months ago #186511
It's paint off the cam shaft ladder gasket.garage showed me it when they did the head gasket. I had no idea how bad the problem would become.
Replied by Daleswalker on topic Wocha bin doin on your MG this week then?
Posted 6 years 5 months ago #186528
Not so much me, but SWMBO hijacked the motor and had some work done on her as a birthday pressie!!!!
Painted brake calipers
New soft top with HRW
Fantastic red cockpit trim and red Alcantara seats
And finally Mike Satur windstop.
I'm a very lucky guy!!!!
Last Edit:6 years 5 months ago by Daleswalker
Last edit: 6 years 5 months ago by Daleswalker. Reason: spelling
Posted 6 years 5 months ago #186529
Very nice mate..I like that!
The following user(s) said Thank You: Daleswalker
Replied by G0RSQ on topic Wocha bin doin on your MG this week then?
Posted 6 years 5 months ago #186537
You will be paying for that later....trust me :dry:
by G0RSQ
Posted 6 years 5 months ago #186538
I think, if she drove, I would be in danger of losing the car to her but she doesn't so I'm safe!!
Posted 6 years 4 months ago #186554
Those alloy doorpins from alloy car parts will be coming off I'm beginning to dislike them..I'm going to get some of better quality...aswell as these not fitting correctly/having to drill them to fit the tf...the passenger side jammed a couple of times...removed the escutcheons for now untill I buy some more...who invented that word escutcheon?....
Last Edit:6 years 4 months ago by mgtfbluestreak
Last edit: 6 years 4 months ago by mgtfbluestreak.
Posted 6 years 4 months ago #186555
Escutheon is French, does that answer your question! I think it has it's origins in heraldry, daft word, but the language would be that little bit poorer without it.
Replied by davidgv1 on topic Wocha bin doin on your MG this week then?
Posted 6 years 4 months ago #186556
Just cleaned inside and out, checked the tyre pressures, screenwash and wiper blades.
MOT and Service tomorrow!!
Fingers crossed
Replied by NigelOBB on topic Re:Wocha bin doin on your MG this week then?
Posted 6 years 4 months ago #186557
Changed rear window zip slider, another job tick on Tifs to do list..
Time to create page: 2.837 seconds
