Posted 6 years 4 months ago #186623David Aiketgate wrote: I just want to say that who ever designed those spring hose clips should be dangled by one attached to his private parts over a pool of piranha!
What's wrong with jubilee clips ?
The top spring clip made a 30 minute job into a 3 hour marathon. :rant: It was aligned perfectly so that it was virtually impossible to get a tool on it!:bang:
They are quicker on the assembly line and cheaper in the accounts office.
Posted 6 years 4 months ago #186624I then modified the cable section so it now bolts to the clutch slave bracket.
Finally I repainted the fuel filter section with primer and satin black.
Today I refitted it.
I have a box full of goodies rom Rimmers that arrived at work while I was on holiday but I've taken a few days compassionate leave so the subframe installation will have to wait a few days.
Replied by NigelOBB on topic Re:Wocha bin doin on your MG this week then?
Posted 6 years 4 months ago #186729Sent from my iPhone using Tapatalk
- gooseholla
Replied by gooseholla on topic Re:Wocha bin doin on your MG this week then?
Posted 6 years 4 months ago #186762John
- gooseholla
Posted 6 years 4 months ago #186810Please Log in or Create an account to join the conversation.
- Chris P Dash
- Apprentice MGer
Replied by Chris P Dash on topic Re:Wocha bin doin on your MG this week then?
Posted 6 years 4 months ago #186812I had to patch up a minor leak on the exhaust near the flexi pipe before I went - I want to replace the exhaust during the winter months so I can take my time (probably most of which will be spent under the car swearing)
A slight panic when she failed on the emissions test but connecting her to an ODBC reader revealed a fault code on the VVC which cleared and stayed clear after that she sailed through :woohoo:
Next day went for a celebratory drive to North Yorkshire - taking 2 hours to do the first 40 miles wasn't much fun but once the traffic finally cleared we had an amazing run.
Replied by davidgv1 on topic Re:Wocha bin doin on your MG this week then?
Posted 6 years 4 months ago #186884And hey they work perfectly.
Replied by Norm on topic Wocha bin doin on your MG this week then?
Posted 6 years 4 months ago #186887Thanks for everything. Norm
Posted 6 years 4 months ago #186895In all probability, sitting on the side of the road in a puddle of coolant and a cloud of steam! :bust:Norm wrote: . Once again the forum has come to the rescue, where would I be without it?
Posted 6 years 4 months ago #186954done some trick door handle lights including wiring them and the logo puddle lights,
and fitted a rivnut (my first ever) to replace one of the damaged subframe mount bolt holes, 2 more to go.
- SundanceUK
Replied by SundanceUK on topic Wocha bin doin on your MG this week then?
Posted 6 years 4 months ago #186956I fitted them a couple of years ago, and it did not take long for them to fail, reason is the door is basically a water drain, and the puddle light driver ( the plastic cylindrical case with the small circuit board in) was sitting in the bottom of the door getting very wet. The circuit is not very well protected against water ingress.
When I fitted a second one, I wrapped it with waterproof tape - and its still working. Since then the other side has also failed, so I will replace this and wrap the new one up too.
Sundance
- SundanceUK
Posted 6 years 4 months ago #186971Also re-painted one of my door car caps, as for some reason the paint had bloomed - possibly with sun and heat over the hot weather, so door card all back on and car looking tip-top.
Only thing left to do is to swap the drivers seat back after it comes back from Bitz after having the bolster fixed.
Sundance
