Replied by NigelOBB on topic Re:Wocha bin doin on your MG this week then?
Posted 6 years 4 months ago #186978SundanceUK wrote: Finished re-building the TF interior and replaced my busted T-bar, long job as I had to cut away for the roll hoops then fix it all back together with the modified wind stop.
Also re-painted one of my door car caps, as for some reason the paint had bloomed - possibly with sun and heat over the hot weather, so door card all back on and car looking tip-top.
Only thing left to do is to swap the drivers seat back after it comes back from Bitz after having the bolster fixed.
Sundance
Fitted the bargain wind stop I managed to acquire, before SWMBO got home.. 😬😬
Replied by talkingcars on topic Re:Wocha bin doin on your MG this week then?
Posted 6 years 4 months ago #186991
- The driving dutchman
Replied by The driving dutchman on topic Re:Wocha bin doin on your MG this week then?
Posted 6 years 4 months ago #187118Verstuurd vanaf mijn SM-G920F met Tapatalk
- SundanceUK
Replied by SundanceUK on topic Wocha bin doin on your MG this week then?
Posted 6 years 4 months ago #187142The controller did have a wire that was supposed to work with this function, however, being a far eastern import, the function only flashed the halo's when the indicators were turned on.
So I wired up two signals from the indicator switch, one for each turn signal and used this to switch two relays, one each side which interupted the current to each pair of halo's when the indicator switch is operated.
I managed to find a nice little recess behind each light unit, with a spare hole to bolt the relay to, so no drilling required.
The job soon done in a couple of hours, with the only problem being a wasp that was mistaking my aircon condenser for a nest!
Sundance
Relay mounted...
And wired....
MG TF wasps nest!
Replied by DougBrum on topic Wocha bin doin on your MG this week then?
Posted 6 years 4 months ago #187146Please Log in or Create an account to join the conversation.
Posted 6 years 4 months ago #187160The driving dutchman wrote: Close to completion Talking cars. Back on the road soon?
I am currently trying to refit my modified heatshield so I can get the exhaust on and finish servicing the drive shafts with the hope I can get the car back down on four wheels tomorrow and in for an MOT the week after next.
Replied by cairnsys on topic Re:Wocha bin doin on your MG this week then?
Posted 6 years 3 months ago #187210One slight oversight on my part - I forgot to tell Jon about the noisy hydraulic lifter and it wasn't until he started the engine after changing the gasket that he knew about it. It would have been a piece of pee to change the lifters while the head was off of course and I should have asked him to do that. His advice was to try a can of Wynns Hydraulic Valve Lifter "magic" and I have to say, it seems to be quieting (quietening?) things down a bit.
Unfortunately, it now looks like I've popped a seal on the clutch slave cylinder, I'm guessing as a result of the car not having been driven for about 6 weeks. Never mind, one on order from Rimmers which should be here tomorrow so that's the next job.
I can't recommend Rough Luck highly enough - they were excellent!
Robin
- sworkscooper
Replied by sworkscooper on topic Re:Wocha bin doin on your MG this week then?
Posted 6 years 3 months ago #187213John
Posted 6 years 3 months ago #187216Robin
Posted 6 years 3 months ago #187223After much blood letting and swearing, I’ve freed and greased the clutch release arm and fitted and bled the shave cylinder. I now have a much better clutch so I suspect the release arm had been tight for some time and am back on the road :woohoo:
In common with other posters, cracking the master cylinder union made bleeding a lot easier
Robin
Posted 6 years 3 months ago #187249When stripping the car i wrapped the cables around the engine, so they didin't get caught up when moving everything around, That was a mistake! Untangling that from underneath and teasing back in to the tunnel was a nightmare :rant:
Posted 6 years 3 months ago #187282All the wiring was in place so it only needed some way of mounting the new motor and connecting it to the latch pull. That was the trickiest thing but I resorted to using a cable tie in the end. I expect it will fail at some point but it will be easy enough to replace with another one.
Robin
