Posted 6 years 3 months ago #187285
Posted 6 years 3 months ago #187286and I refitted the battery to the ZR and pumped a tyre so I'll be able to give it a run, its first in 3 months.
And spent 3 hours on the bathroom roof (single storey) washing the conservatory roof (after next door had building work) in the pouring rain and blustery wind....
And I did do a bit on the F...where the donner TF didn't have ABS the hole on the upper swing arm for the screw that holds the bracket for the ABS cable had never been used, thought I'd use my M6 thread cleaning tool but it wouldn't bite so I used a 6mm wood screw first, then the thread cleaner -
all was going well until...β¦
the thread cleaner sheared!
(think I reached the end of the hole!)
Looking for a positive, I have a stud that will hold the bracket and a 6mm nut
except
the bracket on the MGF is different to the MG TF so that will need to be sorted!
Now to watch Love Island?
Posted 6 years 3 months ago #187287And the week stripping, painting and rebuilding drive shafts.
And yesterday refitting driveshafts and hubs.
and now Love Island After Sun is on.
Posted 6 years 3 months ago #187289Was feeding the bonnet release cable through, got to the footwell and started thinking this cable is a bit short, thats never going to reach all the way. Then it dawned on me , Throttle cable! , Wish i'd spotted that one before putting the Dashboard back on.
Some time spent wedged into the foot well unbolting the pedal (again), Attach cable, and bolt pedal back on. A quick test and pedal springs back but cable doesn't feed back in to the sleeve. Must need adjusting i'm thinking, Clear my way to the engine bay and.. No throttle body.
Tonights Job, Find my throttle body :lol: , oh and the bonnet release cable as well
Posted 6 years 3 months ago #187329
Posted 6 years 3 months ago #187367I also cleaned the threads on the studs for the rear wheels, nuts go on much more easily.
Then made a new bracket for the lead from the offside rear ABS sensor and reconnected all four sensors.
Finally using a long cable tie as a draw I threaded the wiring for the additional door lighting on the O/S through and in to the body.
Replied by NigelOBB on topic Wocha bin doin on your MG this week then?
Posted 6 years 3 months ago #187385I did try to replace the Chavy head unit with an old one I had spare, alas it lasted. 30mins then died π€. Finally I changed the Air filterππππ
Posted 6 years 3 months ago #187389Just got to sort the weep on the rear brake pipe union and the other wheel can go on and we can start thinking about MOTs.
Posted 6 years 3 months ago #187427The extra door lighting works (but how can I make the interior lights come on when you unlock?)
She moves and stops (only got 3 feet to move ).
And she's even had a wash!
Posted 6 years 3 months ago #187433
- SundanceUK
Replied by SundanceUK on topic Wocha bin doin on your MG this week then?
Posted 6 years 3 months ago #187443Jon and Claire Norris also came over to fit a new clutch, thanks to them, the clutch now has a great bite and is so much easier to operate.
Good thing is that it also got a clutch fluid change at the same time. Jon kindly replaced the oil for me while the car was on the stands, so saved me a job of getting the ramps out and doing it myself later!
Also while Jon had the air filter box off, found that the intake pipe hat rotted away - they all go this way eventually, Jon tells me - so out with the Gaffer tape for a hasty repair...should last until I can source a new one!
A very productive day on the TF!
Sundance
Engine bay
Air intake pipe
Posted 6 years 3 months ago #187450
