- SundanceUK
Replied by SundanceUK on topic Wocha bin doin on your MG this week then?
Posted 6 years 3 days ago #188546Could you drop a bit of four core cable in directly from your ECU to the connectors on the O2 sensor, by-passing all of the cars wiring, to prove its not a cable issue.
It seems to me if there is a fault with the probe signal, its either got to be the probe, wiring or connectors or the ECU.
I know you have changed the ECU and probe, not sure what you have done with the wiring but bypassing the existing loom with a temporary cable will prove that out too. If its none of them, then it must be another fault causing the issue.
Sundance
- sworkscooper
Posted 6 years 3 days ago #188552I'm with Sundance's suggestion. Temp wiring and another check .
John
- sworkscooper
Posted 5 years 11 months ago #188629:nonod:
- SundanceUK
Posted 5 years 11 months ago #188673I may have a probe around with my clip on ammeter and see if there is anything I can put onto a switch to help prolong my battery life. I do have a binnacle mounted USB power outlet which is connected to the cigar lighter circuit, hence permanently powered up. This has three very bright LED's and some on-board electronics that may be helping to drain my battery so could be worthwhile putting it onto a switched circuit.
Until then I will make sure the car is fired up at least twice a week.
On the plus side, the weather was exceptionally sunny and mild enough to make the return journey home with the roof down, even with its downsides, the TF still never fails to bring a smile to your face!
Sundance
Posted 5 years 11 months ago #188682There's a k&n filter in there but I haven't a clue how old it is so would have changed it if it hadn't proven so fiddly to get to, I ended up just giving up. What a pain in the arse that they located a service item there .... :bat:
Posted 5 years 11 months ago #188689
Posted 5 years 11 months ago #188690Please Log in or Create an account to join the conversation.
Posted 5 years 11 months ago #188764Please Log in or Create an account to join the conversation.
- mgtfbluestreak
Posted 5 years 10 months ago #188897Time for the ramps out has a belly full of Turkey and beer ain't going under there without them.
New filter purchased before Christmas from local shop...last filter was old stock rover.
New filter below.
Ran the engine for a bit ....seems nice and dry now...:beer:
- SundanceUK
Posted 5 years 10 months ago #188930Anyway, carpets peeled back and I still have water ingress, albeit less than I have been experiencing.
So its out with the trusty fan heater for a full dry-out - again!
Thinking its time to be changing the primary seals now.
Sundance
How to dry out a MG TF!
- mgtfbluestreak
Posted 5 years 10 months ago #188933Please Log in or Create an account to join the conversation.
- SundanceUK
Posted 5 years 10 months ago #188934Apart from that there is something about a roof down ride on a fine and frosty winter morning!
If I did had a garage, I would probably buy a very low mint example and just use it very sparingly....
The ZT-T is a great winter car and I am trying to keep the bulk of the mileage on it during the winter, also having limited mileage (5000 per year) due to having the TF on a classic insurance, I am trying to save the miles up for the summer...so hoping to just put somewhere between 500 to 800 miles on the clock between now and May. It will help as I am having a year off FRL this year!
Sundance
