Replied by Gavin207 on topic Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189293Please Log in or Create an account to join the conversation.
- mgtfbluestreak
Posted 5 years 9 months ago #189297.on looking around at what others used I found this......a flipping sparkplug
Replied by Steve on topic Re:Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189299Get as much in and air out as possible cold and the run up, as the stat opens you will get a sudden drop in level, turn off and let it cool a little then top up, keep an eye and bleed two or three times after runs and it will be fine, always bleed with the heater on hot.Gavin207 wrote: Refilled the cooling system after replacing damaged coolant hose and skimmed cylinder head. Followed the recommended sequence, but surprised it only took 5 litres so assume there is an air lock somewhere. Car is currently parked facing slightly down hill which I thought would help bleed any air at the expansion bottle, but can only assume the thermostat is stopping air getting through. Plan is to turn the car round quickly so that the coolant pipes are sloping up towards the radiator and help gat air out. Any other recommendations?
Sent from my SM-G950F using Tapatalk
- Squashman56
- Journeyman MGer
Replied by Squashman56 on topic Re:Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189303The NS M8 bolts came out with no problem and I thought I was on a winner and looking forward to an early finish!
No such luck with the OS bolts as both bolts sheared off leaving me with no choice but to drill out both bolts and re-tapping of the threads. Several hours later I then had to cut back both M14 bolts so that I could get them out.
After de-rusting and painting the sub frame area with Bilt Hamber I was then able to fit the new St Stl mounts + new M14 bolts. To make life easier I did decide to fit the new M14 bolts the opposite way round.
Finally sprayed the new mounts with copper spray and fitted plastic end caps to prevent water egress into the mounts.
Never got round to the liquid re-fill but there is always next weekend!!
Posted 5 years 9 months ago #189319Gavin207 wrote: ….Car is currently parked facing slightly down hill....
Advice is to raise the rear of the car so parked nose down should help.
Replied by talkingcars on topic Re:Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189320
Posted 5 years 9 months ago #189321creating a permanent slot car circuit to run my 2 6R4s, 4 MG Lola LMP cars and 3 MG maestros and other cars.
Replied by Gavin207 on topic Re:Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189330Please Log in or Create an account to join the conversation.
Posted 5 years 9 months ago #189359A bit of oil in the water and water in the oil ( both replaced) after the HGF. What do people recommend for flushing the oil and cooling systems?
Replied by salona on topic Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189361Please Log in or Create an account to join the conversation.
- sworkscooper
Posted 5 years 9 months ago #189365Please Log in or Create an account to join the conversation.
- sworkscooper
Replied by sworkscooper on topic Re:Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189368Gavin207 wrote: Ran the car up again until the thermostat opened, still no more air out - can only assume the radiator didn't drain when I disconnected the pipes under the floor. Took the car out for a 25 mile drive, no more air out, so seems all ok - temperature sitting just below centre.
Always used Forte Bio degreaser when I was in the trade . Used it on my ZR when the HGF. Ran it for about 4-5 days then drained and flushed the cooling system . Not a sign of oil after that. As for the engine oil , just a good flushing oil will do .
John
