Replied by MGTF2004 on topic Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189381
Just brought some alcantra seats for my tf.
They're filthy but I've spent a few days cleaning them they're starting to look good.
As soon as eBay drops off the leather cleaner they'll look great
Replied by Raccoon on topic Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189383
MGTF2004 wrote: Just brought some alcantra seats for my tf.
Rub them with baking powder, let it work for 30mins and hoover then.
Works wonders!
by Raccoon
The following user(s) said Thank You: SundanceUK
Replied by NigelOBB on topic Re:Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189388
Swapped wheels over from black to silver
Before
After
Posted 5 years 9 months ago #189389
Thanks I'll try that.
Replied by Squashman56 on topic Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189391
Finally managed to get my TF back on all four wheels after the suspension rebuild.
Hope to get it booked in (as long as the weather stays dry!!) for a 4 wheel laser alignment next week.
A quick blast around the estate confirmed that the coolant bleeding procedure listed in the 'How to guides' is spot on.
Just need to sort out the blowing exhaust flange now and I can then move on to the next phase of the rebuild.
More next week.
Squashman
Replied by vdv on topic Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189393
Fitted two bonnet struts this morning
Having my mk7 tt exhaust fitted tomorrow morning and then its being treated to a new battery.
by vdv
Posted 5 years 9 months ago #189394
Hi vdv,
How well do they work?
Are they easy to fit?
Thinking of fitting these to mine to replace the naff single bonnet rod.
Squashman
Replied by salona on topic Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189427
Just got the SCU back in the car after replacing the faulty Pektron relays. I've seen these for sale on Ebay for £5 per relay but I bought 5 relays from RS Components for £13.50 delivered! The RS Components part number for the relays is 915-6613
Crappy old faulty Pektron Relays
[IMG
Old relays removed
[IMG
Replacement relays all fitted
[IMG
Last Edit:5 years 9 months ago by salona
Last edit: 5 years 9 months ago by salona.
Posted 5 years 9 months ago #189435
I tried to install pscan on my new laptop, and, like most things to do with my MGs, I failed.
Getting more than a little fed up now.
Replied by SundanceUK on topic Wocha bin doin on your MG this week then?
Posted 5 years 9 months ago #189437
Brake calipers all stripped and cleaned, a fresh coating of anti-seize on the pads and slide shims and handbrake set up.
I usually do this every year in May just before the MOT, but with the car having less use over the winter now, I noticed the handbrake was beginning to stick. Wheels thoroughly washed too while they were off the car and deep cleaned with purple rain.
Its good to do the AP front calipers at least once a year, as the retaining pins do seize up and can be a mare to remove, an annual clean up keeps them nice and free.
Sundance
The following user(s) said Thank You: NigelOBB
Time to create page: 2.765 seconds
