Replied by SundanceUK on topic Wocha bin doin on your MG this week then?
Posted 8 years 4 weeks ago #172816
David Aiketgate wrote: My little baby is being operated on. :dry:
Two new lower front wishbones, some new brake pipe and, hopefully, an MOT tomorrow. :hugs:
New wishbones - deffo the way to go...nearly a new car again! Hope the MOT is trouble free!
Sundance
Posted 8 years 4 weeks ago #172839
:woohoo:
Wishbones changed. No snapped bolts! :omg:
Brake pipe renewed. :yesnod:
MOT passed. :broon:
No advisories. :woohoo:
Total price - £138! (I did supply the wishbones.)
I believe that is what can be called - A result !
Replied by COMMANDER on topic Wocha bin doin on your MG this week then?
Posted 8 years 4 weeks ago #172865
Last weekend I repalced the back box and heat shield. It was an after market box and did not fit too well. Also one of the captive nuts for the hanging brackets was missing. Lots of seized and / or rusted bolts and much pushing and shoving, with of course the obligatory scuffed knuckles. But with a bit of outside the box brainwork the job was completed after eight hours of lying under the car. Not bad for a 71 year old I reckon. Then went for a nice spirited drive on the new toyos fitted the previous weekend. :drive: :woowoo:
Replacement Exhaust Rear Back Box Silencer 2 Year Warranty - Brand New!
Buy It Now
Last Edit:8 years 4 weeks ago by COMMANDER
Last edit: 8 years 4 weeks ago by COMMANDER. Reason: added link
The following user(s) said Thank You: David Aiketgate, mgtfbluestreak
Replied by kaspian on topic Wocha bin doin on your MG this week then?
Posted 8 years 3 weeks ago #172906
Gearbox cable ends finally arrived from *bay . Hopefully dry tomorrow so I can fit them . The old ones were in poorcondition and one hsd completely come apart with the rubber disintegrating causing the loss of all gear selection. With any luck the gear selection will improve as the ball end on the crank at the gesrbox was also loose . It is rivited into place so careful application of hammers tightened it up a treat.Fingers crossed!
by kaspian
Replied by GilesH on topic Wocha bin doin on your MG this week then?
Posted 8 years 3 weeks ago #172907
Ian S wrote: Starting the hunt for the elusive coolant leak on daughters tf115. I've always had a gut feeling that there may be a problem since we got the car. But after 5k miles the nagging doubt has resulted in about 12mm drop in level but only after a 100mile run at motorway speeds, normal town driving no loss.
My monies on the inlet manifold or water pump.
Head gasket was replaced along with the latest design oil raill by a reputable MG garage in the Oxford area so hopefully I can rule that out.
Don't know if you found the source of the leak, but I just had to replace my heater control valve (behind the dashboard) because it had a small leak (1 drip every minute or so) when turned all the way off. Only found it because I was pulling some cables through the middle of the car for a reversing camera.
Last Edit:8 years 3 weeks ago by GilesH
Last edit: 8 years 3 weeks ago by GilesH.
The following user(s) said Thank You: David Aiketgate, cairnsys
Posted 8 years 3 weeks ago #172925
Nice new sunstrip fitted.
Posted 8 years 3 weeks ago #172983
Changed the gearbox cable ends today .20 minute job and now the gearchange is fantastic! Decided to take the car out for a run to celebrate only to find that after 2 miles it started pulling to the right , lost power and came to a halt in a cloud of ferodo smoke witn a siezed front caliper. I'd forgotten the joy of owning a british built car ........but its all starting to come back to me ! Oh well out with the spanners again.... :woohoo:
by kaspian
Posted 8 years 3 weeks ago #172992
COMMANDER wrote: Last weekend I repalced the back box and heat shield. ........ the job was completed after eight hours of lying under the car. Not bad for a 71 year old I reckon. Then went for a nice spirited drive on the new toyos fitted the previous weekend. :drive: :woowoo:
Buy It Now
wow take a leaf out of that mans book.....i thing people born in 1945 are made of stronger stuff....nothing deters them......... :clap:
The following user(s) said Thank You: COMMANDER
Replied by Alans835 on topic Wocha bin doin on your MG this week then?
Posted 8 years 3 weeks ago #173076
MG tinkering has been slow of recent, moving house a week an Friday. I will have a nice big garage though to tinker soon.
On another note I made the practical classic mag this month
Thanks
Alan
The following user(s) said Thank You: David Aiketgate, Blow-in, cairnsys, The driving dutchman, mgtfbluestreak
Posted 8 years 2 weeks ago #173098
I've fitted a digital volt meter
Here is the 'how-to'. Open door, sit down, remove cigarette lighter (if still present), insert digital meter, align as required.
It's a key controlled socket so with the ignition on you can read the battery voltage and when running you can see the alternator output. Useful? Certainly more useful to me than the lighter.
I bought this one via Amazon for £2.54 delivered (it does take a few weeks) although there appear to be identical units for even less money.
See: https://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=well-goal+mini+led+volts&rh=i%3Aaps%2Ck%3Awell-goal+mini+led+volts
Richard
by Blow-in
Posted 8 years 2 weeks ago #173145
Yesterday I fitted a new stainless steel oil filler housing bracket.
This is the item:
MGTF MG TF Upgraded Stainless Oil Filler Housing Bracket New mgmanialtd.com
Completed
The previous owner had fitted an after market bracket with loads of spacing washers - why? Perhaps the bolt he had was too long?
I could see that it was failing and that was confirmed on removal:
The easy way to fit the new bracket is to undo the bolt to the inlet manifold (13 mm socket), remove the dip stick then pull up the whole housing. The bracket can then be replaced on the bench (garden not work bench in my case):
On first refitting I didn't use any spacers and was a tad concerned that the bracket was contacting the inlet manifold and the vibration could lead to wear:
So I refitted it with a spring washer as a spacer and am more than happy with the results.
Richard
by Blow-in
Posted 8 years 2 weeks ago #173147
:broon: I think we MG owners must be part Magpie! :vulture: We do like our shiny bits and pieces, lol. ;)
:coat:
Time to create page: 4.143 seconds
