- sworkscooper
Posted 8 years 1 week ago #173538Please Log in or Create an account to join the conversation.
Posted 8 years 6 days ago #173540CyprusMGTF wrote: .......ODB gives no faults, although the temperature seems to read a bit low (86 to 95 during normal driving, outside temp 25 degrees) which could cause over fueling, I do get the occasional backfire after the bogging down
Those temps are about right but I suppose you could change the coolant temp sensor.
If you only get a misfire under the same conditions everytime, i.e. pulling away at 2000rpm, I'd wonder about a damaged wiring loom.
- CyprusMGTF
- Apprentice MGer
- TF 1.6 MPI
Replied by CyprusMGTF on topic Wocha bin doin on your MG this week then?
Posted 8 years 6 days ago #173559I had a similar problem with my old beetle, it had twin webers fitted and it also had a flat spot under certain acceleration conditions, this I eventually traced to a damaged jet in one of the carbs and the accelerator pump having a weak diaphragm. the symptom on the TF are similar, if i feather the throttle then she pulls away fine albeit slowly, If I set the gas at 2000 and don't let it drop she takes off like a rocket,(needed in Cyprus, Mediterranean drivers and all,) allow the rev to drop and the bogging starts., I cant decide if it is over fueling or under fueling during this time, potentially over fueling due to the occasional backfire.
I have the ODB connected all the time and use Torque app to monitor live to see what is going on, but nothing seems out of place. I guess another look this week end.
Posted 8 years 6 days ago #173560Maybe the spindle of the throttle-body has worn a flat spot on the shaft and the bushes it runs have worn egg shaped in profile, when the most worn area of the spindle shaft lines up with the worn area of the bush it leans out as it can suck more air in though the gap, the area just off idle is usually the most worn. This may account for your flat spot.
I've occasionally found this to be the problem with flat spots on carbie engines.
Gotta be worth a look anyway, init!
- CyprusMGTF
- Apprentice MGer
- TF 1.6 MPI
Posted 8 years 6 days ago #173561Please Log in or Create an account to join the conversation.
Posted 8 years 6 days ago #173562Have you still got the old one? Did it have the flat spot when it had the old TB? Could you try it with the old one fitted?
- CyprusMGTF
- Apprentice MGer
- TF 1.6 MPI
Posted 8 years 6 days ago #173563Please Log in or Create an account to join the conversation.
Posted 8 years 6 days ago #173567"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Replied by Ian S on topic Wocha bin doin on your MG this week then?
Posted 8 years 5 days ago #173597Please Log in or Create an account to join the conversation.
- CyprusMGTF
- Apprentice MGer
- TF 1.6 MPI
Posted 8 years 5 days ago #173604Was out driving last night the reluctance to accelerated from below 2000 is still there. getting above 2000rpm it is almost like a turbo kick in effect. I will try and record is and post.
Replied by COMMANDER on topic Wocha bin doin on your MG this week then?
Posted 8 years 3 days ago #173658Please Log in or Create an account to join the conversation.
Replied by jelly on topic Wocha bin doin on your MG this week then?
Posted 8 years 3 days ago #173664Please Log in or Create an account to join the conversation.
