Posted 7 years 6 months ago #177394I snatched a few minutes after the rain stopped and started fitting the hubs back on the car - the thread on the top bearing on one side is damaged and there is no allan key recess to stop the bearing turning so there is no chance of getting the bolt done up, I guess I'll be getting some new ones of them too.
- SundanceUK
Replied by SundanceUK on topic Wocha bin doin on your MG this week then?
Posted 7 years 6 months ago #177433MOT pass with no advisories. Its a great feeling that all of your hard work has paid out...and you have to admit, our cars can be high maintenance, especially if you use them daily!
Sundance
Posted 7 years 6 months ago #177436I noticed that the engine bay fan wasn't connected either! Reconnected that and tested it. Working fine!:yesnod:
I've also noticed the fuel consumption figure has dropped to around 33.5 per gallon , so I'm hopeful that the new temp sensor will see that figure improve.:pop:
- sworkscooper
Posted 7 years 6 months ago #177459Please Log in or Create an account to join the conversation.
- mgtfbluestreak
Posted 7 years 6 months ago #177463Please Log in or Create an account to join the conversation.
Replied by Ian S3 on topic Wocha bin doin on your MG this week then?
Posted 7 years 6 months ago #177530X-power exhaust tomorrow, a rear brake checkover and new gearbox linkages.
The things we do to keep a daughter happy!
- glennrover1960
Replied by glennrover1960 on topic Wocha bin doin on your MG this week then?
Posted 7 years 6 months ago #177534Please Log in or Create an account to join the conversation.
- glennrover1960
Posted 7 years 6 months ago #177535Please Log in or Create an account to join the conversation.
Posted 7 years 6 months ago #177537
Posted 7 years 6 months ago #177539David
- SundanceUK
Posted 7 years 6 months ago #177550Hey up Glenn, what are you doing with your old seats, mate, are they in good nick, cant remember what they were like when I saw your car, but my mate Andy who is in Rocester may be after a set. His cloth seats have seen better days.glennrover1960 wrote: ps.........seats not too bad, 50 quid off gumtree !
Sundance
Posted 7 years 6 months ago #177552Anyway, enough of today - yesterdays fun was on the F - I started replacing the top ball joint on the hub on the nearside, not having a 46mm socket or spanner I used a small drift to tap the old one round to loosen and then did the same to fit the new one. I then refitted the steering arm to the hub and replaced the track rod end. I then took the small lip off the edge of the brake disc and brushed the rest of it before refitting (remember I was going to replace), finally the brake caliper went back on.
This all went well so I moved onto the off side, the top hub bearing came off and went on with no issues
until
I went to fit the nut - being a cheap skate I had bought the joints only, not the kit, as I planned to reuse the old nuts, however when I took the TF hubs off the TF subframe I had to cut one of the nuts off as it had seized, not a problem as I had the 2 nuts from the F hubs which were the hubs going onto the TF subframe (half the mileage of the TF hubs and with ABS rings), however the thread on the TF ball joints and the new ball joints is more coarse than the thread of the old F ball joints - the result is one nut for two ball joints.
Okay, a bit frustrating, lets move on to the track rod end - would the lock nut come undone - would it F*#%!
Oh well, at least one side was done.
I did consider having another go tonight
except
there are two cubic meters of top soil in the way.
