- glennrover1960
Replied by glennrover1960 on topic Wocha bin doin on your MG this week then?
Posted 7 years 6 months ago #177555Please Log in or Create an account to join the conversation.
- glennrover1960
Posted 7 years 6 months ago #177698Please Log in or Create an account to join the conversation.
- SundanceUK
Replied by SundanceUK on topic Wocha bin doin on your MG this week then?
Posted 7 years 6 months ago #177733Sundance
- SundanceUK
Posted 7 years 6 months ago #177767While the front bumper was off, decided to remove and refurbish the bonnet catch guard and lubricate the bonnet release catch cable.
Rusty screws replaced with new stainless ones and new mesh in the front bumper grilles.
One thing I found useful was how low the ARB can be dropped now I have rose jointed droplinks instead of the standard ones, also good to see how well they have stood up to a years hammer of potholes use. They should hopefully last the lifetime of the car since there is no rubber to perish.
Now my subframe and front underbody is all treated and coated and will be ok for the next few years!
Sundance
Replied by jelly on topic Wocha bin doin on your MG this week then?
Posted 7 years 6 months ago #177811Please Log in or Create an account to join the conversation.
- SundanceUK
Posted 7 years 6 months ago #177812They are really robust and have no rubber bush to fail. They come with M10 spigots, so you can throw away the old bolts and use the spigots to mount them.
This is what they look like..
And here fitted...
The ramps are ace, but they do need a lower angle ramp extension for use when the bumpers are on.
Mrs Sundance treated me to them for Christmas, but I suspect they are available on Ebay.
The extension ramps I got for them are Sealey ones. However I did have to modify the hooks on them to fit my big red ramps.
The ramps come with two 2 ton jacks so you can get those valuable extra inches....think my missus is trying to tell me something there!
Sundance
- glennrover1960
Posted 7 years 6 months ago #177819Please Log in or Create an account to join the conversation.
Posted 7 years 6 months ago #177823Literally just that, didn't even take the nut off as I did that yesterday.
I did however spend most of the day with my kids celebrating my grandsons birthday and when I got home we were doing ground works for our forth coming 7m by 5m deck.
Replied by Keymaster on topic Wocha bin doin on your MG this week then?
Posted 7 years 6 months ago #177855Easy to fit with spray adhesive, but the corners were tricky. Only cost £20.00 for the material and adhesive. Good improvement I think; so I deserve one of these :clap:
:clap:
- adamelphick
Posted 7 years 6 months ago #178078One of the original struts was a nightmare to get off.... finally CUT the top nut off the rear passenger side strut..... It was stuck on the upper arm so bashed it with a mallet and it flew apart and spring oil poured everywhere!!
The internals had come undone and I think were just holding together as it was jammed between the top arm and the top of the strut support in the subframe!
The Bilsteins have transformed the ride today..... so much nicer.
- BruceTF135
Replied by BruceTF135 on topic Wocha bin doin on your MG this week then?
Posted 7 years 6 months ago #178080I removed the cover from the back of the lamp
You can see the scorched yellow wire. The insulation on the blue wire has disintegrated
The connector has melted too
I cut the wires about 3cm from the connector as the insulation seemed OK here
Here is the new connector, tinned and ready to go, complete with heat-shrink tubing
All soldered and insulated.
Ideally, I would have liked to have replaced the whole length of wire (the leads on the new connectors were long enough) but I couldn't figure out how to. The offside dipped headlight not quite so bad but will be repaired the same way. The main beam lights are perfect, presumably because they don't get used as much, as talkingcars suggested.
- glennrover1960
Posted 7 years 6 months ago #178081Please Log in or Create an account to join the conversation.
