Replacing internal heater pipes, day 3
So far the gear lever mech, heater control pod, cross member thingy support behind it, srs unit, a mass of wires that are routed in between various pipes, nooks and crannies. Small floods of coolant that decided to wait until I put my head just where it run anywhere a towel had not been laid. Then finally accessing the pipes in the engine bay, found that the only way to remove the old pipes was to angle them up into the dash, into the heater vent and remove the rubber pipes from the end. Finally the faulty one is out. Dread revering the process, but very grateful for David's how to pipe layout diagram as the carefully marked notes telling me which rubber pipe was fitted to the correct metal pipe was rubbed off during the battle to disengage each other.
Really, were the Rover engineers who designed these cars on drugs?! They really couldn't have made the design more complicated if they tried!
Anyway, deep breath and cup of coffee in hand - question to the sane.... The old pipes contained a load of rust and debris, which is floating around the system. Should I flush the system out, and does anyone recommend a particular flush to use? Any pointers and advice on the procedure would be appreciated.
Replied by talkingcars on topic Replacing internal heater pipes, day 3
Posted 8 years 6 months ago #167752
- sworkscooper
Replied by sworkscooper on topic Replacing internal heater pipes, day 3
Posted 4 years 4 days ago #194650John
Replied by Raccoon on topic Replacing internal heater pipes, day 3
Posted 4 years 3 days ago #194651Please Log in or Create an account to join the conversation.
Replied by Keymaster on topic Replacing internal heater pipes, day 3
Posted 4 years 3 days ago #194653This is not a job I have had to do yet, but surely there must be something more flexible and resistant to corrosion that would replace existing.
I'm thinking on the lines of silicone hoses, but there will be alternatives.
- julianfoulger
Replied by julianfoulger on topic Replacing internal heater pipes, day 3
Posted 4 years 1 day ago #194659Frankly, I would replace ALL the rubber hoses whilst you are at (budget permitting) including the valve and heater matrix (only if you can buy new).
In my experience, cars (in fact all manufactured items) are designed to be built quickly and cheaply, not taken to bits. Audi is the same.
It is a job that I never want to do again. Best of luck.
Why does the heating flow and return pipes have to be replaced with steel again?
The original steel pipes lasted 25 years. So another 25 years should be fine? No!
Posted 3 years 11 months ago #194716I want to strip out the interior of the F next summer, this could be a job to look at whilst it is stripped.
Replied by gloscs on topic Replacing internal heater pipes, day 3
Posted 3 years 11 months ago #194742Please Log in or Create an account to join the conversation.
