Removing & refitting the bottom pulley nut
Removing & refitting the bottom pulley nut was created by Steve G
Posted 6 years 9 months ago #183857
Hi, I'm new to T-Bar, and about to replace the cambelt on my 2009 TF (N-series engine, 14.5k miles).
The Rimmer Bros "how-to" video suggests using an air gun to remove the bottom pulley nut and I assume they use the same method to re-tighten it. I have a fairly comprehensive toolkit but I don't have an airgun or a flywheel locking tool.
Before searching for the locking tool, I thought I would ask if anyone had any other suggestions and/or advice. Many thanks if you do.
Steve G
by Steve G
Replied by sworkscooper on topic Removing & refitting the bottom pulley nut
Posted 6 years 9 months ago #183859
Hi Steve .
The crank pulley nut on all the K series engines I worked on were a really bitch to undo . In a workshop with all the tools at my desposal I found the impact gun and socket would undo some but not all and sometimes had to resort to Snap On's longest breaker bar to crack the buggers! On a two post ramp it felt as though I was going to pull the car off the ramp . It would depend if the N series is assembled by technicians with arms like The Mad Muller on steroids as to how tight their pulley nuts are . Have a look at the How to's on the forum.
Without a tool to lock the crank I think you will find it a struggle .
Regards John .
Replied by G0RSQ on topic Removing & refitting the bottom pulley nut
Posted 6 years 9 months ago #183860
I have to agree with john.
I have done the job three times, the second time because I did not tighten the pulley bolt up enough !!
You can try it in gear with wheels on ground and brakes applied, but there is so much give and twist in all the components that you think something will break!
Spend the money on a crank locking tool (like I should have done first time) and save some real heart ache.
The bolt is really tight, and even then a long breaker bar (3-5 foot) will be needed.
by G0RSQ
Replied by mgtfbluestreak on topic Removing & refitting the bottom pulley nut
Posted 6 years 9 months ago #183861
If your anywhere near stoke on trent I could lend you the locking tools and large breaker bar.I used them on my tf with no problem.but like John said they are tight.
Last Edit:6 years 9 months ago by mgtfbluestreak
Last edit: 6 years 9 months ago by mgtfbluestreak.
Replied by talkingcars on topic Removing & refitting the bottom pulley nut
Posted 6 years 9 months ago #183867
I bought a Ryobi one impact driver for the job.
Replied by Borypops on topic Removing & refitting the bottom pulley nut
Posted 6 years 9 months ago #183868
I would be interested how you get on with that I am thinking of buying one .
Replied by jelly on topic Removing & refitting the bottom pulley nut
Posted 6 years 9 months ago #183869
Haven't done the TF but a while ago I tried and failed to do a Citroen C5 HDI but then had to do another C5 hdi but the difference this time my mate lent me his unit with a air powered rattle gun it was a revelation don't know the torque's but it just undone it like it was nothing. Wont be trying it again without a gun.
by jelly
Replied by Steve G on topic Removing & refitting the bottom pulley nut
Posted 6 years 9 months ago #183873
Many thanks, it sounds like I need to invest in the flywheel locking tool.
by Steve G
Posted 6 years 9 months ago #183874
Hi thanks for the offer, unfortunately I'm not near stoke, I'm down near the south coast.
by Steve G
Posted 6 years 9 months ago #183875
I'll update the post when I've done the job, thanks for all your replies
by Steve G
Replied by kevocouk on topic Re:Removing & refitting the bottom pulley nut
Posted 6 years 9 months ago #183913
Hi, i did my TF160 belts today, my Ryobi one impact wrench took the pully bolt off. I used it to put it back on, then torqued it with car in 5th gear and brakes hard on. Maybe i was lucky? Impact wrenches are great, one of my best investments, whips wheel nuts etc off too.
The following user(s) said Thank You: talkingcars, Borypops
Replied by Rich in Vancouver on topic Re:Removing & refitting the bottom pulley nut
Posted 6 years 9 months ago #183916
I have a cheap electric impact gun (Came free with an impact socket set!) It isn't the best but has removed crank bolts from two K4s and a KV-6 without issues. (Cams locked, car in gear with a foot on the brakes and a strap wrench holding the pulley steady as insurance!)
The following user(s) said Thank You: Leigh Ping, Borypops
Time to create page: 0.544 seconds
