Rear sub-frame mounts
- Squashman56
- Journeyman MGer
I'm sure instructions must be hidden somewhere in the vast knowledge banks of our members, but I'm struggling to find them.
Any ideas on where to look for simple instructions on how to replace the front mounts on the rear TF subframe.
So far I've only been able to find comments about cutting off the heads of the 14mm bolts and then reversing the direction of the bolts on re-fitting.
What I've not been able to find is any photo's or 'How to guides' of the actual procedure for replacing the mounts.
Just hoping that this procedure is straightforward and has been documented many times and that I've just not been looking in the right location for the info.
Thanks.
Squashman
- SundanceUK
I then drilled out and helicoiled the two M8 threads to accept the new bracket and put the big M14 bolt in the opposite way around (ie from the rear of the car) and but the nut on inside the brackets hollow section.
Just enough room to get a socket on and tighten up.
The other side was much easier as the two M8 bolts came out without any problem.
Doing it this way you can replace the mounts without dropping the subframe, just make sure you torque up the main 14mm bolts.
Sorry but I do not have any pictures of this, but before you start, make sure you have a set of cobalt drills handy in case you need to drill out the bolts if they snap off, they are hard. Helicoils may also be required. Its pretty self explanatory really, so the above description should be enough for you to do the job. The big 14mm bolts are too long to remove in one piece so it has to be cut. Have a replacement for these also before beginning. Cutting the bolts and refitting the other way around is much easier than dropping the subframe. You may find it easier to grind the nuts off these long bolts also.
Sundance
- Squashman56
- Journeyman MGer
Sounds like I need to allow a long day for this, just in case of sheared bolts (which seems to be the norm with virtually all TF bolts!).
Looking at the state of the round sections on one of the existing mounts its nearly all corroded away so shouldn't have much issue getting the M14 bolt out.
- Squashman56
- Journeyman MGer
Did you need to cut the old M14 bolt out as Sundance did or will the bolt come out in one piece?
https://www.mgexp.com/phorum/read.php?54,3669589,3669589#msg-3669589
[size=10pt]Mark[/size]
95 MGF
- SundanceUK
If you contact MGFnTFbitz and tell them what you are up to, they will send you a full set of correct nuts and bolts to do the job, they have stainless mounts in various colours too. Remember its tight to get a socket on the bolthead inside the mount when tightening back up, but its just do-able.
If you spray lots of penetrating oil on the 8mm mount bolts, and use an impact gun, you may stand a better chance of shifting them without pinging the bolt heads off.
Sundance
- Squashman56
- Journeyman MGer
Really hope it doesn't come to a welding up exercise as that's not my field.
Having said that looking at your MGF photos it looks like your subframe is in a far worst condition than mine.
Anyway we will see how I get on.
- Squashman56
- Journeyman MGer
I have already got a full set of St Stl mounts (did the ones on the front subframe last weekend) + fittings etc so, having read the various responses I'll just get prepared with everything I can think of and have a decent flask of Coffee on standby!
95 MGF
- Squashman56
- Journeyman MGer
As I've only recently acquired my TF, the shopping list price for new bolts will soon outway the cost of the car itself!!!
