Enamel badges - fade and go chaulky
Replied by sworkscooper on topic Enamel badges - fade and go chaulky
Posted 5 years 2 months ago #191420
Hi Nik .
I like most on here have had the same problem. Have you considered changing the MG part of the badge with the gel style stick on insert type . I changed mine 4 years ago from the original and they still look fine . All you need to do is make sure that the chrome base octagon area is clean and dry before you apply the new gel insert . I'll have a look to see where I bought them unless someone on here beats me to it.
John
The following user(s) said Thank You: NikTheGeek
Posted 5 years 2 months ago #191421
Hi Nik .
You'll find the inserts here at MGMANIALTD.CO.UK
Posted 5 years 2 months ago #191422
Sorry the link is working . Just look at the mgmanialtd.co.uk site and you'll see them .
Replied by BruceTF135 on topic Enamel badges - fade and go chaulky
Posted 5 years 2 months ago #191424
Posted 5 years 2 months ago #191425
Cheers Bruce .
Replied by Gavin207 on topic Enamel badges - fade and go chaulky
Posted 5 years 2 months ago #191436
As I like a challenge, is it possible to renovate ‘milky’ badges? Can the discolouration be polished out or does it go too deep?
Replied by Bob on topic Enamel badges - fade and go chaulky
Posted 5 years 2 months ago #191437
I have the gel ones on my TF the solid enamal ones lasted no time at all, less than 18 months.
The gel ones are 3 years old and still look like new.
I got mine here, I needed the whole badge because the gel inserts will not sit on the enamel ones.
Got mine on fleebay
MG TF FRONT OR REAR BADGE , BRAND NEW, GENUINE (DAB000160)
Buy It Now
Last Edit:5 years 2 months ago by Bob
Last edit: 5 years 2 months ago by Bob.
Posted 5 years 2 months ago #191438
Gavin207 wrote: As I like a challenge, is it possible to renovate ‘milky’ badges? Can the discolouration be polished out or does it go too deep?
Well a challenge is one thing but I think you will find that within a few months you will have to do it again . I had some very smart black and chrome after market ones on my ZR and after the first winter they had gone dull and after I spent an age polishing them it didn't seem long before I was doing them again .
John
Replied by NikTheGeek on topic Enamel badges - fade and go chaulky
Posted 5 years 2 months ago #191439
I'm not sure I understand the gel insert thing. How do inserts work on my existing badges as surely they would sit proud?
Posted 5 years 2 months ago #191440
The original manufacturer's badges are nothing more than thin lacquer and once you have carefully scraped them off and cleaned the surface the gel insert sit perfectly within the octagon chrome mounting . If you look at the original badges they have a slight recess and gel replacement sits snugly within the recess .
You won't be disappointed with them , just make sure the base of the octagon where the insert sits is clean and dry and if possible warmed with a hair dryer to give good adhesion .
John
Replied by Leigh Ping on topic Enamel badges - fade and go chaulky
Posted 5 years 2 months ago #191441
NikTheGeek wrote: I'm not sure I understand the gel insert thing. How do inserts work on my existing badges as surely they would sit proud?
Gel Badges. Click, click.
Time to create page: 2.707 seconds
