Roll Hoops
Hi all i have a mgtf 2002 and i want to put some roll hoops on, but i have a rear glass window my question is which sought wouls fit ie the sought that lean fwd or the sought that sit straight up.
by p38
Most roll hoops are only cosmetic, mostly they only bolt onto flimsy sheet metal with no bracing and are only made from flimsy thin wall tubing.
So if you are after protection............don't bother, proper roll over protection isn't going to be a quick bolt on fix.
Unfortunately the layout and compact nature of our cars doesn't lend themselves to a quick easy fix, there is little space to put proper load spreading mounting points and accommodate brace bars.
In fact most of these things are probably more dangerous fitted than doing without, in a rollover they are likely to significantly deform on impact....with the distinct possibility of making contact with the occupants heads when they do.
Worthwhile protection needs to be engineered and integrated into the structure of the car.
Compromises to cockpit space, access and convenience, that such a proper rollbar would require don't much matter on a race car, but won't be much fun in your daily driver or weekender.
I've had the dubious pleasure of race cars on the road, whilst it's a bit of fun, you wouldn't want to live with the compromises, and the first one that comes to my mind is the rollbars.
Now I'm not saying don't fit one for cosmetic purposes, if you love the look by all means fit one, but don't try and kid yourself or anyone else that it's a safety feature,
I have Satur Boxer mk1 hoops and wind break and they work fine with my glass rear window.:yesnod:
Most are OK with a rear glass screen but the X power MK 1 roll hoops are not.
Mk 2 X power hoops however do.
I have included an image of the MK 1 so as you know what not to buy.
Last Edit:4 years 7 months ago
by Bob
Last edit: 4 years 7 months ago by Bob.
The following user(s) said Thank You: p38
- SundanceUK
Spot on Bob,
I have a glass screen and Mk2 rollhoops that go straight up. They are fine with the rear window and do offer an amount of rollover protection too.
Sundance
Sundance
by SundanceUK
Time to create page: 0.502 seconds
