Coolant alarm magnet has become detached
Coolant alarm magnet has become detached was created by Gavin207
Posted 2 years 2 months ago #199899
I have a 2004 MG TF with the original coolant alarm fitted when I recently check the coolant level I found the needle magnet lying in the bottom of the expansion tank I've read about these magnets becoming detached and wondered if anyone has any experience of reattaching the magnet to the float
Replied by sworkscooper on topic Coolant alarm magnet has become detached
Posted 2 years 2 months ago #199902
Hmm , going have to check mine now aren't I ? You just know if I don't it be me at the side of the road with steam coming from every orifice !
John 👍
  • Away
Replied by Cobber on topic Coolant alarm magnet has become detached
Posted 2 years 2 months ago #199906
John 👍
You should probably see a doctor about that! :omg:
Posted 2 years 2 months ago #199907
:yesnod: :slapme:
Replied by SundanceUK on topic Coolant alarm magnet has become detached
Posted 2 years 2 months ago #199911
I had the same on my latest TF, Unfortunately no sign of the magnet though! Had to buy a new expansion tank.....nice and crystal clear! May be a better option as it was hard to find one, Only place that had them in stock was Brown and Gammons. Maybe some more have come into the country by now!
Sundance
The following user(s) said Thank You: Gavin207
Replied by Gavin207 on topic Coolant alarm magnet has become detached
Posted 2 years 2 months ago #199912
I have a feeling that the float and magnet are assembled before the two halves of the tank are welded together so reinserted the magnet could be a challenge.
Does any one know where the magnet inserts? Is it in the bottom or side of the float? Any photos of a dismantled expansion tank would be a great help if anyone has a failed tank.
In case anyone is interested the magnet is 2mm in diameter and 20mm long.
Last Edit:2 years 2 months ago by Gavin207
Last edit: 2 years 2 months ago by Gavin207.
Replied by Roverlike on topic Coolant alarm magnet has become detached
Posted 2 years 2 months ago #199913
I hope you ment vice versa: 20mm in diameter and 2mm long.
Posted 2 years 2 months ago #199914
No it's a cylindrical 'bar' magnet
Posted 2 years 2 months ago #199915
Ok, then this is the page to help you with pictures where that type of magnet should be:
http://www.apttony.co.uk/Servicing/CoolantAlarm.html
Last Edit:2 years 2 months ago by Roverlike
Last edit: 2 years 2 months ago by Roverlike.
Posted 2 years 2 months ago #199925
Took a picture of the float with my endoscope today - you can see the hole for the magnet in the float. Next is to try reinserting it with my trusty surgical clamp.
Replied by neilpinleeds on topic Coolant alarm magnet has become detached
Posted 2 years 2 months ago #199927
When did the coolant alarm become standard?
Posted 2 years 2 months ago #199928
Mines 05 reg, built in Feb 05 , I think they started fitting them late 54 reg but I could be wrong .
Time to create page: 0.581 seconds
