EPAS and PSCAN
PScan, Sykes ACR 4 POD4 or G2 pod, SP SPi, Delphi DS100/150, TopDon-ArtiDiag BT808.
I have tried a few OBD 11 scanners but none seem to have the correct protocol which I believe is IS09141 and as I'm running mine as a stand alone system it may not like it not being OBD 11 compliant.
Based on my testing 82hz equates to 2460 rpm
The speedo reads 1MPH per 1 Hz so your signal equates to 19 to 295MPH = What made you chose those frequencies
I have read somewhere that if the ECU see an engine speed of more than 2500 for more than 30 sec with no speed input it will go into fail safe mode so perhaps that's why its set to the equivelent of 2460 RPM on pin 15.
In testing the EPAS will run without a speed input on pin 7.
Attached a pic showing my testing using MGTF speedo which shows frequency to Speed is 1-1
I have mine running of ECU rpm signal and a separate speed pickup but was having issues. I then realised I had an early EPAS ECU so changing to the 720.
Would be good to do the same testing on the MGF to workout what frequency it is sending to the early EPAS ECU
Is your steering very light ?
Have attached later and early type wiring diagram that I'd been working from
