MG TF cut out and unable to restart
Driving home from a shopping trip last Thursday and slowing down approaching a set of lights car just cut out and hazard lights were activated. Car would not restart. No loud bangs when it went and AA guy said it sounded ok when cranking, Cam Belt and Water Pump done about 20k miles and just over 4 years ago along with HG certificate from Trophy Cars on that.
AA recovered after being unable to get it going but found Fuse 2, one of the 30A engine management ones under the bonnet had blown. Tried replacing and its blowing as soon as ignition is switched on, even tried a 40 amp one and same happened.
Weather has been pants so haven't been able to get the hard top off and start removing the t bar to get at the engine and fuel pumps but wondered if anyone had encountered anything similar with the hazard lights being activated with the ignition and not from the switch. Could a fault in the fuel pump cause the fuse to blow?
I am going to get access and remove connections to Inertia Switch and Fuel Pump when I get the chance but thought I would ask here as the hazard activation is perplexing.
Cheers,
AJ
- sworkscooper
Replied by sworkscooper on topic MG TF cut out and unable to restart
Posted 1 year 6 months ago #202158I have no doubt that the good folk on here will come up with something that will point you in the right direction.
John
Replied by Roverlike on topic MG TF cut out and unable to restart
Posted 1 year 6 months ago #202160Please Log in or Create an account to join the conversation.
When I get a dry evening I will get the hard top off, remove the t-bar and speakers to be able to get access to the fuel pump and try disconnecting that and see if the fuse still blows. Reading that the fuel pump is only energised at when key is turned to position 2 is making me hopeful this could be the issue but its the hazards thats confusing me, can't find anything similar in any forums of information online.
**Edited to add found green wire at boot loom has broken which should hopefully fix 3rd brake light when I get round to fixing that**
Battery connections were showing 13.99v with engine running and dropped to 12.92 once engine was off. Will check what the battery is showing in the morning and may take it to the local motor factors for a load test. hopefully looks like a potential combination of low battery and dirty/poor connections.
Had to post back as one of the most annoying thing I find with forums is the vast majority of OPs never respond with a final resolution once they are sorted.
Thanks @Roverlike and @sworkscoooper for the pointers and helping find some other items for me to fix
- Away
Replied by Airportable on topic MG TF cut out and unable to restart
Posted 1 year 6 months ago #202165So thank you aj76, even though I didn't contribute I'll sneak a bit your politeness to make up for the times we've been pissed on.
Welcome aboard
Replied by Notanumber on topic MG TF cut out and unable to restart
Posted 1 year 6 months ago #2021732003 TF 135 sunstorm
The poor old boot hinge does get some stick (most of it justified I think) but if ones gone??? I hate to be a merchant of doom but maybe all that opening and closing of the boot has remade a dodgy connection albeit temporary. Your opening thread thread mentioned shopping did this go in the boot just before the breakdown?
To echo what was said thanks for closing this thread or have I just reopened it!
I had dropped the shopping off and driven approx 3 miles since boot was last opened when the car cut out.
I had wiggled the wires in the boot loom area and was still having issues with the fuse blowing.
Battery voltage checked and was less than 12V so put on charge
Chain of events in last session before getting it running.
Whilst battery was finishing charge removed all 3 relays from the boot near side.
Using the guide mentioned in previous post, tested the relays using multimeter, test light and one of my motorbike batterys.
new 30A fuse in bonet Fuse 2
Identified Fuse 23 in passenger compartment was also part of this circuit so due to discolouration on the legs opted to change this for a new 15A fuse
Fitted now 80% charged battery (as it was charging on outdoor socket and rain was due) using a green scotchbrite to clean the battery terminals and connections
Refitted the relays in the boot one at a time, after fitting each one turned ignition firstly to pos 2 to check for hazards before trying ignition. Fitted fuel pump relay last of the 3
With car running wiggled boot loom just to be doubly sure.
After leaving the battery overnight with my isolator switch turned off it had dropped to 12.3V, the start was laboured a little but it did start but from my understanding that would indicate a failing battery of about 70% health
I went through the paperwork for the car and found the battery reciept, was new beginning of Feb 2022 and had 3 year warranty checking on the suppliers website. Called their local branch and they agreed to replace under warranty. It was a cheap own brand battery i had never heard of so opted to pay a little extra for a brand I have more confidence in.
Used some cheap wire drill brushes I had to really clean the battery connection and also the earth strap connection and fitted the new battery and used dielectric grease which was not used previously.
- S_Hadley1138
- Novice MGer
Replied by S_Hadley1138 on topic MG TF cut out and unable to restart
Posted 1 year 6 months ago #202354I've just posted this issue with mine
https://www.the-t-bar.com/forum/9-mgf-tf-pitstop/98465-map-sensor-reading#202353https://www.the-t-bar.com/forum/9-mgf-tf-pitstop/98465-map-sensor-reading#202353
but I've also noticed the alarm has become temperamental in the past month too, and that can be a symptom of a break in the boot hinge loom, I've read
Tested all the relays in the boot again and found that fuse 2 blew only when ECM relay was put in. So am I looking at the ECU thats in the boot or is there another unit I should be looking for?
Edited to add, having removed the ecu the fuse only blows when the small connector at the top is connected so guessing it is that unit. Will be looking for someone local to test it and hopefully it is the fault and can be repaired
If the problem resides within in the ECU, it will be buggered!
