Passenger side window intermittent
Passenger side window intermittent was created by Borgy
Posted 1 year 5 months ago #202383
Like it says on the tin, the windows works when it wants to and doesn't work when it cant be bothered.
I have read a few places that it might be the replays in the BCU?
Is this likely?
Is it an easy swap
by Borgy
Replied by deepfat on topic Passenger side window intermittent
Posted 1 year 5 months ago #202387
You need to find out what you have depending on your Vin as the systems are different, I know if you have an SCU they are soldered in.
by deepfat
Replied by Notanumber on topic Passenger side window intermittent
Posted 1 year 5 months ago #202393
Personally I would start by temporarily wiring a bulb in parallel with the window circuit so that next time it fails you can see if its the relay/ECU that is failing to provide an output or if its' the motor itself/ wring to the door.
Replied by j0ris on topic Passenger side window intermittent
Posted 1 year 4 months ago #203058
If it is ONLY the passenger side window, I would check if the problem isn't with the switch. Swap the switches of both windows and see if it's now the driver side window acting up.
Last Edit:1 year 4 months ago by j0ris
Last edit: 1 year 4 months ago by j0ris.
  • Away
Replied by Cobber on topic Passenger side window intermittent
Posted 1 year 4 months ago #203063
The first place I’d look is the switch, the contacts are probably filthy, I’ve written a how to on here somewhere….was quite a few years ago.
Replied by SundanceUK on topic Passenger side window intermittent
Posted 1 year 4 months ago #203091
Passenger side window is controlled directly from the switch, the drivers side has relay control from the BCU because of its semi automatic operation. It will either be the switch, broken wires in the door where it hinges or the window regulator unit (motor) at fault. Switches are easiest to check and would be prime suspect.
Also the window regulators have a plastic bevelled drive gear that can wear, causing intermittent operation, but usually it goes down but not up when this occurs.
Sundance
Posted 1 year 3 months ago #203415
Interestingly my passenger window has packed up whilst I was changing my brake pads.
It's not the switch - no difference when i swapped it for the drivers side.
It's not the motor - works when I applied 12 volts directly to the motor.
Is there a relay or a fuse I should be checking out please ?
Its a 2003 TF, different fusebox from that of the earlier TF and Mk2 F that I had just started to understand.
Replied by Roverlike on topic Passenger side window intermittent
Posted 1 year 3 months ago #203416
Yes, there is a window lift relay and two fuses. One under steering wheel fusebox and another under bonnet fusebox. Described here: https://www.the-t-bar.com/forum/roverlike-s-guides/97846-mg-f-tf-fuse-relay-listing
Posted 1 year 3 months ago #203418
Thanks for the link. The fuses are fine but there is no power getting as far as the + feed to the passenger window switch. I've also swapped the relays around. Odd as there's very little to go wrong on the passenger side window and it was fine until I put the car on axle stands on friday to do the brake discs. Intriguing
Last Edit:1 year 3 months ago by Notanumber
Last edit: 1 year 3 months ago by Notanumber.
Posted 1 year 3 months ago #203421
BCU unit controls the relay which provides power to the passanger side switch. It prowides ground connection to relay when engine is started, or just contact given. By that relay coil is energized and you get power to the switch.
Posted 1 year 3 months ago #203424
Thanks. It's odd for the BCU to suddenly stop sending a switched negative to the coil of the window lift relay for the passenger window but everything else to work ok including the more complex drivers side window.
Ive been looking at the wiring diagrams. The first thing that occurred to me was to run a permanent negative to the relay but Im assuming that would have the effect of keeping the relay permanently powered up as the other side of the relay coil looks to be an unswitched positive.
That would seem to leave the options of:
1. Find the BCU, check it's wiring connectors and if no obvious issue then open it up and check for defective solder joints. (Is this viable to open it up ?)
2. Remove the relay and bridge it's switch contacts so it is permanently applying power as far as the passenger window switch. ( I doubt this would be
detrimental to the car's security as someone would have to be inside to open the passenger window - and all they would be able to do is open the passenger window. )
3. run an unswitched negative to the window relay to replace the switched negative from the BCU. Then remove the existing live feed to the relay coil and replace this with a feed that is only live when the ignition is on.
Posted 1 year 3 months ago #203431
Any thoughts on whether the BCU can be opened up non destructively please ?
Time to create page: 0.557 seconds
