Re:LAMBDA SENSOR MG F MK 1
Hello I cant find my lambda sensor on my MK 1 MG F. I`ve looked on the CAT Or is it in the engine bay area Any clues please Len
Last Edit:1 year 5 months ago
by digcot65
Last edit: 1 year 5 months ago by Raccoon.
by digcot65
Thanks I thought I may have a super de-lux model that didnt need a Lambda !!! I admit I was getting worried Thanks again I suppose I could get one of my ring spanners and cut a notch in for the wire Len
by digcot65
I bought a special slotted socket to remove my Lambda sensors but ended up using an open ended spanner
by Notanumber
Hello I had a pre MOT and the exhaust reading was high,and I was advised to replace the Lambda sensor Who are the best people to supply the correct one Len
by digcot65
- billcoleman
- Journeyman MGer
I noticed that you don't have a heatshield over the exhaust manifold. Hopefully it was removed for the photo?
If it is actually missing I would advise fitting one as it gets very hot around there and will effect the alternator and add more heat to the bulkhead heatshield.
by billcoleman
I do have it but I was looking for the Lambda thanks Len
by digcot65
How difficult is it to get to the Lambda sensor and to remove it Is it done by removing the rear wheel Len
by digcot65
Morning how difficult is it to replace Len
by digcot65
It's imposible to replace Len!
On the other hand to replace a sensor depends on the replacement. I bought two one was a kit version the other had a hard wired plug. The plug didn't match the fitted one so I used the kit.
I jacked the rear of the vehicle up, placed it on axle stands and slid under! The lambda sensors are accessible but a crowfoot span/socket is advisable. I removed the old one and installed the new one following the kit instructions. I had to cut the plug off the old one and wire into the new one!
Hope this helps, Dave.
by TaffD
I forgot to ask,what size socket do you need for the Lambda Sensor Len
by digcot65
Time to create page: 0.831 seconds
