TF Electrics ?
TF Electrics ? was created by martin l
Posted 1 year 4 months ago #203020
Hi all
The instrument lights on my TF 115 started to flicker slightly this morning and the tachometer stopped working while using the window switch, I asumed it could be the alternator However I have just checked the battery and at rest its 12.5 volts and with the engine running its at 13.9
Any suggestions of what it chould be or where to look whould be appreciated.
  • Away
Replied by Cobber on topic TF Electrics ?
Posted 1 year 4 months ago #203023
Do a load test on the alternator, there are proper gadgets that do this, but you can do a reasonably effective load test by turning some high current drawing items on whilst the engine is running and doing a voltage check.
Heater fan, headlights, wipers etc. You should get a reading in at least the high 12s
Replied by martin l on topic TF Electrics ?
Posted 1 year 4 months ago #203026
Thanks for I'll try it now
Posted 1 year 4 months ago #203027
Just had all lights on plus heated screen and gettin reading of 13+. So maybe to many short journeys lately
Replied by Notanumber on topic TF Electrics ?
Posted 1 year 4 months ago #203028
Is it only the window switch that has that effect ?
Replied by EllisoJo on topic TF Electrics ?
Posted 1 year 4 months ago #203030
On my 2002 TF, the window switches are on the same fuse as the instruments (Fuse 1 as I recollect) so if that circuit is dragged low, OR the switch and instruments share a poor earth connection, use of the window switch might cause your instrument flicker?
Replied by TaffD on topic TF Electrics ?
Posted 1 year 4 months ago #203031
If there is a poor earth ie high resistance in the window circuit other paths to earth will be sought, it can throw up some odd results try checking the earth to your window switch'. I'm not a TF electric expert but many vehicles have a common earth site if this has corrosion it can throw up these types of issues.
by TaffD
Replied by deepfat on topic TF Electrics ?
Posted 1 year 4 months ago #203059
As mentioned pull the fuse (1) and check it and its holder for corrosion and clean it up, regarding earth/ground points this is a very good guide showing locations.
https://www.the-t-bar.com/forum/roverlike-s-guides/97850-mg-f-tf-earth-points-locations-guide
by deepfat
Posted 1 year 4 months ago #203070
Thanks all for your help.
I charged the battery and went for a good run for an hour and touch wood its been ok since then. So i,m putting it down to too ment short jouneys
So thats the TF sorted so now to the problems with the F (but thats for another post )
Time to create page: 0.565 seconds
